Thread: Hinson Heads ___S3x___or S2x? What Timing setup?
Results 21 to 40 of 55
  1. #21 Re: Hinson Heads ___S3x___or S2x? What Timing setup?
    if you have the 02 engine take that alt and bracket and use it on the 98 motor. the bracket is the same part, n/a or s/c.
  2. #22 Re: Hinson Heads ___S3x___or S2x? What Timing setup?
    GT Level Member PWNED's Avatar
    Jul 2008
    Hooksett,NH
    Thank you for that info guys!
    On another note I emailed a local machine shop about the oil pump cover and the crank gear. This is what they had to say. Any insight?
    ***Regarding the gear, I would need to know the Rockwell hardness to determine if it can be machined. If the hardness requires grinding verses machining, we do not do cylindical grinding.
    Regarding the front cover, we can do flat grinding assuming the part is magnetic. Our surface grinder's size limits are 8" x 20"***
    02 Regal GS
    ZZP Headers/ 42#/ Intake/ S4 zzp sc/ Ported Lim/ LQ4/ HPT/ 3" to SuperTurbo/ Phenolic IC with 2.8 pulley/ XP/ Ported Heads
    PB-------12.3 @ 110.......312hp/350tq
  3. #23 Re: Hinson Heads ___S3x___or S2x? What Timing setup?
    Kemmerer, Wyoming
    the Rollmaster crank gear isn't that hard, the guys I went to didn't have that difficulty. the one I went to just wanted to know precisely how much to remove.
  4. #24 Re: Hinson Heads ___S3x___or S2x? What Timing setup?
    GT Level Member dezebe1's Avatar
    May 2013
    Dallas TX
    Make sure you post up pics of the head work before you install. Do you have experience with porting heads?? Takes a little practice but could save you money in the long run. No Offense to Hinson...seen his work and looks great, it's just how you learn to do it yourself that's rewarding
    Team JB-Weld
  5. #25 Re: Hinson Heads ___S3x___or S2x? What Timing setup?
    Jul 2008
    Hooksett,NH
    As if right now I still plan on Chris to port my heads. But my current issue is that my local machine shop needs to know the grade of metal before they chamfer the rollmaster piece.
    02 Regal GS
  6. #26 Re: Hinson Heads ___S3x___or S2x? What Timing setup?
    Grocery Getter x2 goldgp's Avatar
    redneck tennessee
    That's odd that they need to know that.Shop I took mine too had no issues, I gave them a factory one and said make this like this one,that was it.
    1998 GTP Mods: Getrag 5 speed ,balanced bottom end,ARP hardware,L32 rods,Federal pistons .20 over,XP Cammed,Double roller,130# springs,and 3.4 Gen V,SSC springs,GMPP sways, C5 calipers,12 inch brakes.2000 Grand Prix SE 3.8 Mods: GT dual exaust,plog,downpipe,Transgo Shift kit,1.9 yella terra rr,strut braces,gmpp kit.Both noob tuned with HP Tuner
  7. #27 Re: Hinson Heads ___S3x___or S2x? What Timing setup?
    Mar 2014
    Tucson
    Quote Originally Posted by PWNED View Post
    Hit it with a hand file. If it cuts, it's under 54rc. Should be able to machine it with regular carbide tooling.
  8. #28 Re: Hinson Heads ___S3x___or S2x? What Timing setup?
    Jul 2008
    Hooksett,NH
    Last night I purchased the XP, Roller Master Double Roller and machined pump cover.
    Now I just need to find a machine shop in my area to chamfer.
    02 Regal GS
  9. #29 Re: Hinson Heads ___S3x___or S2x? What Timing setup?
    Pat.. There's a thread on CGP about the DR issue. 400TurbochargedSBC did a huge write up on it and also posted the exact specs here too. Technically when you measure and want perfection, the cam gear is also slightly machined. There is a difference in the crank shoulder where the gear sits. The DR that ZZP sells (and was involved in the thread with the issue, however leaves that out of their site) is made for an Aussie 3.8L crank, not the US version so the chamfer is incorrect on the part. Do the gear, do the pump cover and you are all set w/o doubling gaskets.
  10. #30 Re: Hinson Heads ___S3x___or S2x? What Timing setup?
    Jul 2008
    Hooksett,NH
    Nothing will come up under than name for some reason..
    Will I be ok with the zzp oil pump cover? From what your saying besides the crank gear needed to be chamfered the cam gear as well needs to be?
    02 Regal GS
  11. #31 Re: Hinson Heads ___S3x___or S2x? What Timing setup?
    Jul 2008
    Hooksett,NH
    02 Regal GS
  12. #32 Re: Hinson Heads ___S3x___or S2x? What Timing setup?
    GTP Level Member 231FUN's Avatar
    Dec 2011
    Ontario,Canada
    Lots of info here:
    http://www.clubgp.com/newforum/tm.as...&key=&language=
  13. #33 Re: Hinson Heads ___S3x___or S2x? What Timing setup?
    Dec 2011
    Ontario,Canada
  14. #34 Re: Hinson Heads ___S3x___or S2x? What Timing setup?
    Jul 2008
    Hooksett,NH
    I am unable to ask Turbocharged400sbc if he can do this for me. (full inbox) I am one to get things done right the 1st time!
    02 Regal GS
  15. #35 Re: Hinson Heads ___S3x___or S2x? What Timing setup?
    Jul 2008
    Hooksett,NH
    I got ahold of GR8racingfool and he is able to chamfer that crank gear
    Can anyone chime in on what Turbocharged400sbc was stating about the cam gear needing some taken off as well? In the upper thread?
    02 Regal GS
  16. #36 Re: Hinson Heads ___S3x___or S2x? What Timing setup?
    Jul 2008
    Hooksett,NH
    Besides the machined oil pump cover the biggest thing to get fixed is chamfer the crank gear right? Is this what everyone is doing? Nothing needs to be done to the cam gear correct?
    02 Regal GS
  17. #37 Re: Hinson Heads ___S3x___or S2x? What Timing setup?
    Kemmerer, Wyoming
    correct
  18. #38 Re: Hinson Heads ___S3x___or S2x? What Timing setup?
    The ideal is have the chain and two gears vertically lined up. The crank gear doesn't sit against the crank properly because it's for a different engine. Once it's machined to the right shape, apparently it'll be too short, so the cam gear could use a few thou taken off to get the two gears perfectly lined up.
    Have the crank gear machined, and measure the rest. That's my advice.
    The two gears will be very close once you machine the crank. That's the key bit.
  19. #39 Re: Hinson Heads ___S3x___or S2x? What Timing setup?
    Jul 2008
    Hooksett,NH
    Does anyone how much will exactly need to be taken off the cam gear?
    02 Regal GS
  20. #40 Re: Hinson Heads ___S3x___or S2x? What Timing setup?
    hangover park IL
    that depends on where the crank gear ends up during the test fit after the chamfer and the corner getting squared up on the recess.
    as long as the recess depth is not changed....most Cam motion (intense) fit at .024-.030 and the comp cams at .022-.026 off the backside of the gear.
    make sure the gear is fully deburred (the alignment dimple keeps it from sitting flat on a lathe/surface grinder.
    ~James~ Psychotic Gearhead
  1. BlueNick's old heads/cam setup
    By PurpleGuy in forum For Sale - Parts
    Last Post: 09-23-2014, 03:12 PM
  2. Help on crack heads..need advice on l26 heads
    By crazybrownklick in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-25-2013, 10:07 AM
  3. double timing vs stock timing chain
    By Dam20735 in forum General Tech Discussion
    Last Post: 05-24-2013, 12:53 PM
  4. Rollmaster Double Timing Chain + XP Cam + Ported heads
    By GOTIT4CHEAP16 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-26-2012, 09:02 AM
  5. Spark Plugs/Gap/Timing recommendations for my 2.7" setup?
    By geforcextreme in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-06-2009, 10:48 PM
