Thread: Rollmaster Double Timing Chain + XP Cam + Ported heads
Results 1 to 12 of 12
  1. #1 Rollmaster Double Timing Chain + XP Cam + Ported heads
    GTX Level Member GOTIT4CHEAP16's Avatar
    Bowie, MD
    I am starting a XP cam + Ported heads build and getting rid of my VS cam. I purchased a used Rollermaster Double Timing Chain. I will also be purchasing a Machined Oil Pump Cover from zzp.
    ZZPerformance - Machined Oil Pump Cover #ZZ-OILPCVR
    What needs to be done in order for me to run the Rollermaster Double Timing chain set?
    Gen V, 3.0, Stage 2 heads, XP Cam, SD Headers, N*, LQ4, ZZP Stage 2 Gen 3 Intercooler, CAI, AL 104's Gapped to .055, #130 Springs, 42.5lb Injectors, ZZP Tune.
  2. #2 Re: Rollmaster Double Timing Chain + XP Cam + Ported heads
    Bowie, MD
    ooookay nm then
    Quincy, Mass
    Take the bolt and gear off the balancer and install the double roller. And your done. Put on the new oil pump cover and 2 paper gaskets and your good to go. Don't forget to put the crank sensor back in before those 2 bolts go in.
    No more GP 04 Impala SS Indy:
    Bowie, MD
    Thanks swiggs.
    Sent from my SGH-T989 using Tapatalk 2
  5. #5 Re: Rollmaster Double Timing Chain + XP Cam + Ported heads
    SE Level Member oldsman105's Avatar
    Queens, New York
    Doesn't the gears of the double roller need to machined? Look In max's alero build thread.
    2002 Pontiac Bonneville SSEi
    Gen V with 3.6 pulley , 1.9 Rockers, L76 Springs, N* TB, 40lb injectors, Power log, 3" Down-pipe
  6. #6 Re: Rollmaster Double Timing Chain + XP Cam + Ported heads
    Banned
    Sioux Falls, SD
    Quote Originally Posted by oldsman105 View Post
    It is best to have it machined that way you would no longer have to have a machined oil cover nor a double gasket. A machine shop machined mine for $15 which is cheaper that a machined cover and double gaskets. I have a double chain for sale
  7. #7 Re: Rollmaster Double Timing Chain + XP Cam + Ported heads
    Banned
    Sioux Falls, SD
    Before:
    After:
  8. #8 Re: Rollmaster Double Timing Chain + XP Cam + Ported heads
    Bowie, MD
    Ok guys in order to save me some money from buying the machined oil pump and extra gasket ill get the gear machined.
    How certain is it that i wont have any chain rubbing problems if i get the gear machined? I dont wanna not buy the machined cover and extra gasket and end up having to take the timing cover off again.
  9. #9 Re: Rollmaster Double Timing Chain + XP Cam + Ported heads
    Banned
    Sioux Falls, SD
    because the chafer of the aussie based crank is diff than the american crank, what causes the rubbing it the chafer of the crank gear
  10. #10 Re: Rollmaster Double Timing Chain + XP Cam + Ported heads
    Quincy, Mass
    You should still use 2 paper gaskets if your not going with the machined cover, my gear is machined and it has still rubbed against the oil pump cover. Machining it is going to cost about as much as the cover but you should do it anyways.
    Bowie, MD
    Ok cool guess ill just do all 3 to be on the safe side.
  12. #12 Re: Rollmaster Double Timing Chain + XP Cam + Ported heads
    get the gear chamfer corrected and mill down the oil pump cover .020".
    do not run two gaskets. it's a waste of money and time, you do not need it. it's also a good place for leaks.
  1. Replies: 4
    Last Post: 01-14-2012, 03:40 AM
  2. Need Rollmaster Single Roller Timing Chain Reviews
    By Rolling Thunder in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-08-2009, 07:55 AM
