Thread: Abs light/traction light
Results 1 to 8 of 8
  1. #1 Abs light/traction light
    Feb 2015
    saginaw
    Hi my abs and traction light will not go out scanner is not picking up any codes.. I cleaned all the hub sensors out replaced the front 2 hubs because one was bad and tested the harness's. I had to unplug my display to get the beeping to stop... My abs module is making a ticking noise?? I have been told that may be the problem? If anyone has any other input it would be awesome at this time hahah
  2. #2 Re: Abs light/traction light
    ecbm could be bad. normal scanner wont pull the codes tho, you need a tech 2 or a snap on scanner. most shops will charge for the scan if they dont do the repair work.
  3. #3 Re: Abs light/traction light
    SWPA
    Rear hubs can also cause the ABS light to trip.
    Also, the scanner Advance Auto uses told me which hub had the issue when my light was on. Mine was just a broken wire though.
  4. #4 Re: Abs light/traction light
    05 up cars seem to be able to get the abs codes with a normal scanner. older cars are sol there.
  5. #5 Re: Abs light/traction light
    Feb 2015
    saginaw
    Well i replaced the abs module and the lights stopped blinking but still on. So i was able to plug my display back in with out the annoying beeping.. but its still throwing the track off light.. steering and abs light but i can clear my display and wont keep popping up. Hmmmmmm?? What next??? Anyone???
  6. #6 Re: Abs light/traction light
    the abs code hods the key.
    if you cant scan it.
    could be a bad hub. each wheel jacked up, lugs tight, see if the wheel has play, push pull the top of the tire. if you feel any play that hub could be bad. check all 4 wheels.
  7. #7 Re: Abs light/traction light
    GTP Level Member
    Oct 2014
    Broken wire is common. But that would throw a solid light.
  8. #8 Re: Abs light/traction light
    SWPA
    Quote Originally Posted by markpa View Post
    Not necessarily. I had the broken wire issue and sometimes my light wouldn't trip until I hit a bump.
  1. Traction Off and ABS Light
    By matt311 in forum General Tech Discussion
    Last Post: 05-13-2012, 10:39 AM
  2. Traction control light and abs light on
    By Torri040 in forum Brakes/Suspension/Chassis
    Last Post: 09-02-2011, 04:03 PM
  3. ABS Traction Off Light
    By Phrozen99 in forum Brakes/Suspension/Chassis
    Last Post: 07-29-2011, 08:17 PM
  4. ABS and Traction light
    By nanuke in forum Brakes/Suspension/Chassis
    Last Post: 12-31-2009, 01:19 PM
  5. ABS / Traction Light
    By bcrosby51 in forum General Tech Discussion
    Last Post: 12-20-2008, 06:10 PM
