First off... if I search Rod, it fails because the word is too short.
second, if I search connecting rod, or piston rod, the search only searches for Connecting, or Piston, and NOT rod.
So, I must start a new thread for something that has likely been answered a hundred million times, but please help me out.
I have a 01 Series II supercharged engine with a bad rod. I want to buy a new rod, but I see there is possibly two different types, one for Series II and another for Series III. Everyone sells the Series III rod, but I cant find anyone who sells a Series II.
For instance, ZZPerformance says their rod PN- 12593375 is for 04+
However, I go to GMPartsDirect, they have the same part number as above...and they say that part works for both Series II and Series III. I even had them double verify because I didn't believe it. Well, they said it would work, so I bought it. I have it in my hand now, but it does not look like what I have in my engine. This rod has two tangs in each half to locate the bearing. Of course, if you know what im talking about, then you will know my Series II Rods only have one tang per half, therefore the bearing set for a 01 rod will NOT work in this 12593375 part number rod.
so, can I use this rod anyways, if I get the proper bearing? I am thinking not because Bob Cox says they are shorter and lighter, therefore if I only replace one, then I will crash and be out of balance, correct?
Does that mean this part number will work, but I must replace all 6? I don't want to do that.
Really this comes down to... What is the correct GM Part Number for the rod I need? Where can I get one? I have been setting on this damn thing for 3 months now and its really getting old. Please help me out so I can get this moving again.
Thanks
Shawn
