Thread: Help with Rod Replacement... yes I searched.
Results 1 to 20 of 84
  1. #1 Re: Help with Rod Replacement... yes I searched.
    Moderator Russosaur's Avatar
    Apr 2012
    Dayton, OH
    Instead of being defensive you could always explain "what you have going on" and it would avoid these comments and make people more willing to help you.
    2012 F150 STX
    - Gonna be a race truck
  2. #2 Re: Help with Rod Replacement... yes I searched.
    SE Level Member nukkinfuttz's Avatar
    Sep 2012
    Richmond Va
    I clearly explained my question... it was, "what is the part number and source for a rod?" That's all I asked. I would guess since it was so hard to find, someone here would say
    Quote Originally Posted by Reptile
    " That is the rod number. In 05-06 GM superseded the part numbers for the rods from the series 2 engines to the series 3. They're not the same rod at all, the newer part number is powdered metal, the older number is forged. You cannot use the number that they provide now in that engine without buying all 6.
    which somehow took 16 replies to get to.
    Or maybe someone could have linked me to an old thread containing the info I was asking for if they knew of it. Simple.
    and thank you Reptile, I was afraid that was going to be the answer. In that case, then I will certainly have to abandon the idea of purchasing a new rod and instead try to find a used one. Im definitely not trying to buy 6 rods. This will help me narrow my search efforts a lot.
    91BerettaGTZTurbo=Holset HX-35,26PSI,Bored,EagleRods,WisecoPistons,O-rigned,TitanCopperHG, adj Cam Gears,Custom turbo mani,TurboSmart36mmWG,Screamer Pipe,Custom 3"turboback,MSII-E, LC1Wideband, PyroMeter,KnockSense,Walbro 255LPH,75lbs/hr inj's,3"Core42"Wx15"T IC,HKS BOV Waterinjection,antilag,6puckClutch,Slicks, just needed a Part Number
  1. Ok...searched high and low with no results, so here it is:
    By NCBikerBoy in forum General Tech Discussion
    Last Post: 07-08-2013, 06:10 PM
  2. CAI-Already searched the forums
    By Bkindhart in forum 04+ Specifics
    Last Post: 04-24-2013, 09:13 PM
  3. 3.29 Question, and i searched a LOT
    By steves86ta in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 07-12-2012, 12:45 PM
  4. HEADER Q''S (searched for but no luck)
    By speed demon in forum General Tech Discussion
    Last Post: 06-14-2012, 12:28 PM
  5. A/C Troubles, I'm all searched out.
    By JESSEGOTTA GP GT in forum General Tech Discussion
    Last Post: 04-17-2010, 04:58 PM
