Thread: Help with Rod Replacement... yes I searched.
Results 1 to 20 of 84
  1. #1 Re: Help with Rod Replacement... yes I searched.
    SE Level Member nukkinfuttz's Avatar
    Sep 2012
    Richmond Va
    well, seeing as I paid 500.00 for a 01 Bonneville that's fully loaded, and I already purchased a crank kit... spending another 50 bux on a rod is still a good deal.
    so, where can I get a rod?
    91BerettaGTZTurbo=Holset HX-35,26PSI,Bored,EagleRods,WisecoPistons,O-rigned,TitanCopperHG, adj Cam Gears,Custom turbo mani,TurboSmart36mmWG,Screamer Pipe,Custom 3"turboback,MSII-E, LC1Wideband, PyroMeter,KnockSense,Walbro 255LPH,75lbs/hr inj's,3"Core42"Wx15"T IC,HKS BOV Waterinjection,antilag,6puckClutch,Slicks, just needed a Part Number
  2. #2 Re: Help with Rod Replacement... yes I searched.
    Quote Originally Posted by nukkinfuttz View Post
    you'll want the block align honed at least if you plan on doing this.
  1. Ok...searched high and low with no results, so here it is:
    By NCBikerBoy in forum General Tech Discussion
    Last Post: 07-08-2013, 06:10 PM
  2. CAI-Already searched the forums
    By Bkindhart in forum 04+ Specifics
    Last Post: 04-24-2013, 09:13 PM
  3. 3.29 Question, and i searched a LOT
    By steves86ta in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 07-12-2012, 12:45 PM
  4. HEADER Q''S (searched for but no luck)
    By speed demon in forum General Tech Discussion
    Last Post: 06-14-2012, 12:28 PM
  5. A/C Troubles, I'm all searched out.
    By JESSEGOTTA GP GT in forum General Tech Discussion
    Last Post: 04-17-2010, 04:58 PM
