Thread: kr spike during wot shift
Page 2 of 2 FirstFirst 12
Results 21 to 26 of 26
  1. #21 Re: kr spike during wot shift
    Buffalo
    Full maintenance check before any tunes or kr discussions
  2. #22 Re: kr spike during wot shift
    Nov 2011
    Omaha, NE
    Huh?
  3. #23 Re: kr spike during wot shift
    GTP Level Member tomtom123's Avatar
    Aug 2011
    Michigan
    I think what he's saying is check plugs/wires/other maintenance issues before he talks about kr.
    So you had kr, then it kinda went away, and now you're back to seeing up to 10°?
  4. #24 Re: kr spike during wot shift
    Buffalo
    Yes. Don't chase your tail over kr until your maintenance is 100%
    That will eliminate a lot guess work.
    I seen a stock air box with a filter thst looked like dead cat, once replaced, cleared up 3* of kr
  5. #25 Re: kr spike during wot shift
    Nov 2011
    Omaha, NE
    Only thing the car really needs maintenance wise is new pads and rotors ( rotors have a nice lip on them) and at some point I need to change the coolant over to the green stuff and supercharger oil. Plugs, wires, tyranny service, oil, etc have all been changed either in the last month or so
  6. #26 Re: kr spike during wot shift
    Apr 2014
    Albuquerque New mexico
    Run it at night in the dark see if you have a spark jumping from a wire. If you had no knock and now you do something has to be going on.
    2003 gtp, 3.4 pulley, ported sc, pacesetter ceramic headers, northstar tb, lq4 maf, HAI, wideband tuned
    245/45/17 on cobra wheels.
  1. Tranny Issue help! 1st shift is slipping/sluggish.2nd and up real quick jerk shift
    By Prixness in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 03-26-2014, 12:28 PM
  2. Replies: 1
    Last Post: 12-08-2012, 07:39 PM
  3. Oil Pressure SPIKE THRU THE ROOF
    By Mr D in forum General Tech Discussion
    Last Post: 09-12-2012, 01:42 PM
  4. 97 GTP Coolant leaking and Temp spike
    By graham25 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-17-2010, 10:49 AM
  5. heat spike
    By undecided in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-01-2010, 12:03 AM
