98gtp, anyone had problems with the a.c.bracket breaking?
The only reason it would break is if the rear metal AC bracket is not installed.
You need the rear bracket, its cast or stamped steel. I made the mistake of forgetting to put the bolts back in the rear on before and broke the front aluminum bracket. also make sure to get the correct size hardware to put into the back of the pump. I put to long of a screw into mine and it ruined the pump.
