Thread: dual valve cover breathers
Results 1 to 5 of 5
  1. #1 dual valve cover breathers
    GT Level Member m17davis's Avatar
    Orland Park, IL
    Has anyone ever done this? Is there any reason or benefit in doing this?
    Ported Gen III ~ 3.4 ~ HAI ~ 180stat ~ 605's ~ Speed Daddy's ~ SLP Catback ~ A/C delete ~ Aluminum Sub-frame ~ AGX Coilovers ~ Vinnie Spacers ~ Fusebox & PCM Relocation ~ Wire Tuck
  2. #2 Re: dual valve cover breathers
    GTX Level Member SnowTh1ef's Avatar
    Aug 2013
    Sandy, UT
    Only benefit would be if for some reason your rear pcv is not functioning.
    04 GTP -HAI, 1.9 rockers.
  3. #3 Re: dual valve cover breathers
    Stock so far right? All you'll do is cause an unmetered vacuum leak.
  4. #4 Re: dual valve cover breathers
    Orland Park, IL
    Gotcha. I was just curious. Thanks tho.
  5. #5 Re: dual valve cover breathers
    Feb 2009
    flintnasty MI
    I run dual vc breathers. Pretty much have to be turbo and making power.
  1. LS4 Valve cover
    By 92builtbird in forum 5.3L V8 (LS4)
    Last Post: 04-27-2014, 08:55 PM
  2. Replies: 8
    Last Post: 03-20-2014, 10:49 AM
  3. Valve cover
    By Akuch26 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-05-2013, 03:17 AM
  4. Valve Cover
    By justaV6 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-25-2008, 09:15 PM
