you should be able to check it at the fuel rail.
its a inspection camera the tip fits in the spark plug hole, and you can see whats going on in the cylinder.
http://www.harborfreight.com/digital...era-67979.html
you can make one too, google it. search plumbing drain inspection cameras. theres a few how to make your own on youtube. for very cheap.
I am yet to see an engine that eats plugs like that that didn't have chipped pistons.
machinegunsquid suggested a bad PCV valve causing air coming out of the oil fill port. That would be the best case scenario. I just picked up a new one for $3 but haven't put it in yet.
Yep, the combination of blow by pressure and the conditions of the plugs do not look good. Chipped piston def seems to be the consensus
