Thread: major problems 01 gtx
Results 1 to 10 of 10
black01gtx major problems 01 gtx 01-13-2013, 10:45 PM
Erik Adam Rodriguez Re: major problems 01 gtx 01-13-2013, 10:51 PM
Erik Adam Rodriguez Re: major problems 01 gtx 01-13-2013, 10:52 PM
Fivefingerdeathpunch Re: major problems 01 gtx 01-13-2013, 10:53 PM
Erik Adam Rodriguez Re: major problems 01 gtx 01-13-2013, 10:56 PM
MoarkatsINmuhtrailer Well the low coolant light is... 01-13-2013, 10:57 PM
Erik Adam Rodriguez Re: major problems 01 gtx 01-13-2013, 10:59 PM
LeadfootCJ7 Re: major problems 01 gtx 01-14-2013, 04:34 PM
black01gtx Re: major problems 01 gtx 01-15-2013, 09:08 PM
busmech Re: major problems 01 gtx 01-15-2013, 09:15 PM
  1. #1 major problems 01 gtx
    SE Level Member black01gtx's Avatar
    May 2011
    fort wayne
    so my car has been slowly gaining more and more problems and im not sure where to start. the key wont come out of the ignition without pushing the button in the column. the dic screen doesn't work and the buttons pulse which increases in speed as the car speeds up. the hud just stopped working. the car wont come out of park unless the blower is turned off. the low coolant light comes on and off but the level is full and uses no coolant. the low trac light comes on when i go to take off every time regardless of take off and forward or reverse. after a few times of that happening the tcs off and abs lights come on. the fans dont work.
    so far i replaced a wheel bearing because it was reading funny on my scanner and the ignition switch. the car has no ses light or stored codes.
    owner of 2 3.8 forced induction vehicles
    2001 grand prix gtx
    1984 grand national
  2. #2 Re: major problems 01 gtx
    GT Level Member Erik Adam Rodriguez's Avatar
    Sep 2012
    bridgeport,NY
    sell it to me
    02 grand prix gt- L67 swap, ZZP 1.0 pcm, thrasher CAI, SLP 2.5 catback, A/C delete, 02 emulator, poly dog bone mounts, 6000k projectors with CCFL halos, 12 in slotted front rotors, ported blower and intake, evap and EGR deleted, 12" kicker cvr with 1000 watt amp, alpine cda 9886 deck
  3. #3 Re: major problems 01 gtx
    Sep 2012
    bridgeport,NY
    no im just messin sounds like a bcm quit on ya
  4. #4 Re: major problems 01 gtx
    Almost sounds like a faulty iginition switch itself with all that going on.
  5. #5 Re: major problems 01 gtx
    Sep 2012
    bridgeport,NY
    ^not to be mean but reread op
    Ohio
    Well the low coolant light is a dirty sensor.. You can unplug that. Otherwise the sensor is about 40-60 bucks.
    Everything else does sound like an ignition switch. But you say you've replaced it... Hmmmm bcm maybe
  7. #7 Re: major problems 01 gtx
    Sep 2012
    bridgeport,NY
    i have a coolant level sensor for ya 20 shipped
  8. #8 Re: major problems 01 gtx
    GTP Level Member LeadfootCJ7's Avatar
    Oct 2012
    Houston, TX
    This may sound crazy. I would double check the install of the ignition switch. Make sure it isn't rotated slightly causing poor connection or engagement. The problems you describe sound all like they could be related to simple electrical problem.
    BCM is a possibility as well, but I would start with cheap / free fixes first.
  9. #9 Re: major problems 01 gtx
    May 2011
    fort wayne
    The cooling fans were not working either and so I ran a new ground to the frame and now they work
  10. #10 Re: major problems 01 gtx
    Donating Users busmech's Avatar
    Apr 2009
    Minneapolis MN
    A lot of unrelaed problems usually points to poor connection or poor ground check all that first ...BCMs dont fail that often Good Luck!!!
    "Turbocharging is nice...but I'd rather be BLOWN!!!
  1. Car. Went through MAJOR problems.
    By 94grandprixNOwhipple in forum General Grand Prix Discussion
    Last Post: 02-22-2012, 10:25 PM
  2. Major dealership problems!!!
    By whiney in forum Off Topic Discussion
    Last Post: 12-18-2009, 11:09 PM
  3. Major Electrical Problems
    By Lighty in forum General Tech Discussion
    Last Post: 12-13-2009, 01:46 AM
  4. Major Problems - Need help, please
    By dellfire in forum Off Topic Discussion
    Last Post: 11-04-2009, 09:37 PM
  5. Major Problems Please Help
    By GTPJOE90 in forum General Tech Discussion
    Last Post: 06-11-2008, 08:52 PM
