Thread: LIM fix NIGHTMARE!!! Now I need heads Ugh!!
Results 1 to 20 of 22
  1. #1 LIM fix NIGHTMARE!!! Now I need heads Ugh!!
    Donating Users Uno99's Avatar
    Appleton, Wi
    Good lord where do I start....PLEASE READ OR SKIP TO THE END I NEED HELP SOURCING SOME L67 HEADS TO GET MY CAR BACK ON THE ROAD. Been away from the GP scene since about 08 when I got in a 20 car pileup in Milwaukee the day before thx giving and my Silvermist cam'd 3.0 beauty got totaled out. I picked up a 2002 GP GTP that MAY OR MAY NOT HAVE 98,000 on it.
    I got the car home and after driving it for a week and checking it over it was apparent that it needed some basic maintenance and the LIM gasket needed to be replaced. So my buddy and I dove into it and as we pull the supercharger I see on the underside of the supercharger snout and back of the supercharger there is a serial number on it in paint marker. Then I see what looks like paint marker on the rear valve cover. There are only a few smudged numbers left of what looks like another serial number and you can tell someone tried to remove paint marker with some kind of thinner or mineral spirits. PRETTY SURE THIS CAR HAS A SALVAGE/JUNKYARD ENGINE and the seller failed to mention that no surprise there. So at this point I make the call to dig in a bit further and remove the heads. Thxfully no chipped pistons. The heads are pretty gummed up and it looks like it may have gotten pretty hot so I bring the heads in to get cleaned up and magnaflux..........GUESS WHAT......both heads are cracked.
    I cannot find any heads locally and looked at the ZZP remaned heads but don't see a L67 option can anyone point in the right direction to source these heads so I can get this baby back on the road.
    Thx for reading.
    02 GTP VS CAM / 3.2 MPS / CAI / SD HEADERS Catless DP & E-Cutout / AEM WB / HPTuners
  2. #2 Re: LIM fix NIGHTMARE!!! Now I need heads Ugh!!
    where are the cracks? in the middle of the valves? if so run em, they are all cracked there.
  3. #3 Re: LIM fix NIGHTMARE!!! Now I need heads Ugh!!
    This! A good portion of us have cracked heads it's common if it's by the valve don't worry.
    04 Comp G.
  4. #4 Re: LIM fix NIGHTMARE!!! Now I need heads Ugh!!
    I have a low milage set of L32 heads if youre interested. Im also located in kenosha, wi.
  5. #5 Re: LIM fix NIGHTMARE!!! Now I need heads Ugh!!
    hangover park IL
    x2 its fairly tough to find a head without at least one crack between the seats....its a royal **** finding two low core shift heads that are uncracked.
    the water jacket is no where near where the crack is...never had one fail a pressure test
    ~James~ Psychotic Gearhead
  6. #6 Re: LIM fix NIGHTMARE!!! Now I need heads Ugh!!
    Appleton, Wi
    yep the cracks are between the valves. I plan on installing my s1x cam and 3.0 pulley and supporting mods from my old setup so Ill really be ok running those heads??
  7. #7 Re: LIM fix NIGHTMARE!!! Now I need heads Ugh!!
    should be just fine. every one who gets them checked finds those damn cracks. they still work.
    just clean the heads up real good, the one is ugly for sure lol
    good time to have them rebuilt while they are off. port em maybe.
  8. #8 Re: LIM fix NIGHTMARE!!! Now I need heads Ugh!!
    Yup you'll be surprised how many of us have heads that have cracks there and we still run them.
    04 Comp G.
  9. #9 Re: LIM fix NIGHTMARE!!! Now I need heads Ugh!!
    hangover park IL
    the TR has two cracked seats and we made 608fwhp at 13to1 afr without any issues...i couldnt find anything worrisome via a cyl leakdown test
  10. #10 Re: LIM fix NIGHTMARE!!! Now I need heads Ugh!!
    Appleton, Wi
    Well I'm glad I posted up thx guys
  11. #11 LIM fix NIGHTMARE!!! Now I need heads Ugh!! UPDATE
    Appleton, Wi
    Big thx to PokerBlakeB He gave me a very fair price for his set of heads and I started to put her back together today.
    Decided to try the speed daddy headers as well. surprisingly no issues major issues with them. I have plenty of clearance between the radiatior fan/shroud. The only thing I had to really do is put a few small bends in my tranny dipstick tube.
    The heads before they were cleaned up.
    Head and intake back on
    Speed Daddy headers and the black valve covers that came with the heads (I also put the oil filler tube on the rear valve cover for a cleaner look.
    Hopefully tomorrow I finish the top up, install my wideband, and HPTune the shat out of it. WOOT!! WOOT!!
  12. #12 Re: LIM fix NIGHTMARE!!! Now I need heads Ugh!!
    Florida
    YAY STUFF!
    Looks good. If you havent already, make sure to clean the headers really well of fingerprints and oils so they dont burn into it and make them look like butt.
  13. #13 Re: LIM fix NIGHTMARE!!! Now I need heads Ugh!!
    Appleton, Wi
    Thx I heard that you need to wipe them down being firing it up. I was thinking some windex and a rag???
  14. #14 Re: LIM fix NIGHTMARE!!! Now I need heads Ugh!!
    Florida
    Any degreaser will work. Windex should, but simple green or similar works like a charm.
  15. #15 Re: LIM fix NIGHTMARE!!! Now I need heads Ugh!!
    The Boss Iceman6669's Avatar
    Jun 2011
    I know I'm a little late to this, but that's the common crack and you'll be fine.
    2011 F-150 Yote powered
  16. #16 Re: LIM fix NIGHTMARE!!! Now I need heads Ugh!!
    GT Level Member RegalGS98s's Avatar
    NJ
    Somehow I haven't seen that crack in any of my 3 sets of heads. Lucky for once maybe. Assume it cracks there because there's no coolant in that area so it gets hotter.
    SMGPFC #0330 - 3.25, Intercooled, Custom Tune, 1.84rr, LS6 Springs, roller timing chain, SLP Headers, Borla Exhaust, built Trans, B&M Trans Cooler, home cut poly uppers, gapless rings, N* TB, Ported heads.
    Soontocome: CAM?, Custom modified M112, home poured Poly Engine and Trans mounts
  17. #17 Re: LIM fix NIGHTMARE!!! Now I need heads Ugh!!
    Apr 2012
    Bancroft. Ontario, Canada
    I've got 2 set's of heads (one set from a regal at a local u-pull-it that had 92kmiles) the other on my 178k gtp i parted out. I read about the cracking from posts on facebook groups, and went to check mine out just to see if mine were, just for laughs. One set was cracked, the ones with 178k, i could nearly fit my fingernail in it, the other set didn't have anything noticeable
  18. #18 Re: LIM fix NIGHTMARE!!! Now I need heads Ugh!!
    Appleton, Wi
    Yep that was where the crack were. So I got it all finished up last night here it is BUT THERE IS A CATCH !!!! there is always a catch when I wrench good lord.
    I decided to painted the S/C with some hi temp ceramic paint and plan to do the usual dogbone/hood mount red as well.
    SO HERE IS THE CATCH.......Im backing down my driveway to take it around the block. When I hit the brakes to sow down at the end of my driveway the pedal goes right to the floor!!!!! One of my brakelines blew out. Now I have to fix that Ugh!!
  19. #19 Re: LIM fix NIGHTMARE!!! Now I need heads Ugh!!
    Feb 2013
    37.295091, -121.930053
    At least that happened now not when you doing 70+
    im a cookie again yay me
    please learn to forum better.
    ^^new favorite quote
  20. #20 Re: LIM fix NIGHTMARE!!! Now I need heads Ugh!!
    NJ
    Why'd you paint the supercharger with ceramic? You want heat to dissipate, not have something hold it in.
  1. Hvac Nightmare
    By sdogg201 in forum General Tech Discussion
    Last Post: 05-09-2013, 11:22 AM
  2. Electrical Nightmare
    By black97GT in forum General Grand Prix Discussion
    Last Post: 03-30-2013, 01:12 PM
  3. Need serious advice about my nightmare car
    By kwk6564 in forum General Tech Discussion
    Last Post: 08-14-2012, 06:54 AM
  4. copper nightmare
    By thomas mcnulty in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-21-2012, 06:36 PM
  5. Is it an electrical nightmare?
    By h0wl0ngcanitbe in forum General Tech Discussion
    Last Post: 01-10-2011, 08:40 PM
