Thread: LIM fix NIGHTMARE!!! Now I need heads Ugh!!
Results 1 to 20 of 22
  1. #1 Re: LIM fix NIGHTMARE!!! Now I need heads Ugh!!
    GT Level Member RegalGS98s's Avatar
    NJ
    Why'd you paint the supercharger with ceramic? You want heat to dissipate, not have something hold it in.
    SMGPFC #0330 - 3.25, Intercooled, Custom Tune, 1.84rr, LS6 Springs, roller timing chain, SLP Headers, Borla Exhaust, built Trans, B&M Trans Cooler, home cut poly uppers, gapless rings, N* TB, Ported heads.
    Soontocome: CAM?, Custom modified M112, home poured Poly Engine and Trans mounts
  2. #2 Re: LIM fix NIGHTMARE!!! Now I need heads Ugh!!
    Donating Users Uno99's Avatar
    Appleton, Wi
    Quote Originally Posted by RegalGS98s View Post
    I guess because its resistant to chemical, chipping, and hi-temps and ceramic is supposed to dissipate heat?? I may be wrong but that's what I though. I also had it laying around from when I painted the rotors on my Charger and also figured I try something different. Its not the end of the world if the S/C hold a bit more heat. I can scan and tune for that with HPT. I'm not trying to get every last drop of HP out of this car its my DD.
    02 GTP VS CAM / 3.2 MPS / CAI / SD HEADERS Catless DP & E-Cutout / AEM WB / HPTuners
  3. #3 Re: LIM fix NIGHTMARE!!! Now I need heads Ugh!!
    NJ
    Quote Originally Posted by Uno99 View Post
    Was just wondering why you put a ceramic on it. As you say it won't be the end of the world when you're not looking for every bit of power, but ceramic does hold heat. They actually make coatings to dissipate heat, but they're a little harder to get. A ceramic I used on my other car I tested with a torch. I increased the temp of the pipe from 600 to over 1000 (temp gun doesn't read any higher) by using the ceramic. Besides the performance benefits, it lowered my underhood temps quite a bit from putting on the exhaust manifolds.
  1. Hvac Nightmare
    By sdogg201 in forum General Tech Discussion
    Last Post: 05-09-2013, 11:22 AM
  2. Electrical Nightmare
    By black97GT in forum General Grand Prix Discussion
    Last Post: 03-30-2013, 01:12 PM
  3. Need serious advice about my nightmare car
    By kwk6564 in forum General Tech Discussion
    Last Post: 08-14-2012, 06:54 AM
  4. copper nightmare
    By thomas mcnulty in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-21-2012, 06:36 PM
  5. Is it an electrical nightmare?
    By h0wl0ngcanitbe in forum General Tech Discussion
    Last Post: 01-10-2011, 08:40 PM
