Thread: Engine swapping help!!
Page 3 of 6 FirstFirst 12345 ... LastLast
Results 41 to 60 of 119
  1. #41 Re: Engine swapping help!!
    Banned
    Jan 2013
    maryland
    Ok guys I'll try everything in the morning and thanks for the suggestions just tryna get this beast running
    Sent from my SAMSUNG-SGH-I747 using Tapatalk
  2. #42 Re: Engine swapping help!!
    Banned
    Jan 2013
    maryland
    Ok here's an update: my lower intake manifold is a mainfold that is cut for the gen v so after replacing the manifold with the gen 3, turned the car on and it shuts on after a couple of startups afterwards I started the car and it just starting and shuts off..smh I just running out of ideas.. engine is out of a 2004 Impala SS that went into my 1997 GTP what can be an issue now vaccum line connections could that be it? Anybody have a diagram I know the 97 is different from the other years
  3. #43 Re: Engine swapping help!!
    you put a l32 in your car? and a gen 5 blower on a gen 3 lim? i think theres a pcv issue you need to deal with being your have to use the TB adapter plate and route the pcv into the TB from your 97.
  4. #44 Re: Engine swapping help!!
    Banned
    Jan 2013
    maryland
    Nope a l67 with a LIM that's made for a gen v but now a gen 3 lim is on it now
  5. #45 Re: Engine swapping help!!
    Which blower gen v or gen III? If your using the gen v you need the gen v lim or you'll have sealing issues.
    04 Comp G.
  6. #46 Re: Engine swapping help!!
    Quote Originally Posted by jayroca View Post
    you cant do that. if its been cut for a gen 5 then you put on a gen 3 blower it will leak. you need a un touched gen 3 lim for that gen 3 blower.
    or put a gen 5 blower on it.
  7. #47 Re: Engine swapping help!!
    Banned
    Jan 2013
    maryland
    Put the gen 3 blower on the gen 3 lim guys that's taken care of.. what about the vac lines when I didn't hook the vac line to the fuel rail it started then cut off that's the best progress I gotten but when I hook the vac line to the supercharger it had issues
  8. #48 Re: Engine swapping help!!
    yes.
    but not one that been modded for a gen 5.
  9. #49 Re: Engine swapping help!!
    Yea you need a unmodded gen 3 lim if you opened up the one you have for a gen V. You probably have a huge vacuum leak.
    04 Comp G.
  10. #50 Re: Engine swapping help!!
    Banned
    Jan 2013
    maryland
    Redcompg you might have something there any ideas where it can be i hear it by the throttle body tps sensor code comes on but I deleted it could it be my vaccum lines
  11. #51 Re: Engine swapping help!!
    GTX Level Member TEK310's Avatar
    Mar 2012
    Dallas
    you dont have any vac lines to your fuel pressure regulator?
    2012 Competition Orange Boss 302 #1769 438rwhp 391rwtq
    intake - off road h pipe - e85 - tune
  12. #52 Re: Engine swapping help!!
    Banned
    Jan 2013
    maryland
    Yeah but I'm tryna figure the right lines go to what I forgot to take a pic of my motor before I reassembled it I know dumb mistake any body have a diagram of the vac lines?
  13. #53 Re: Engine swapping help!!
    Mar 2012
    Dallas
    get in the chat box, a lot faster response. i got you
  14. #54 Re: Engine swapping help!!
  15. #55 Re: Engine swapping help!!
    Mar 2012
    Dallas
    since you didnt want to get in the chat box......
  16. #56 Re: Engine swapping help!!
    Feb 2013
    37.295091, -121.930053
    You know when I installed mine I didnt use any pictures to help me and I got it right the first time.
    im a cookie again yay me
    please learn to forum better.
    ^^new favorite quote
  17. #57 Re: Engine swapping help!!
    Banned
    Jan 2013
    maryland
    Thanks guys predicate this!!!
  18. #58 Re: Engine swapping help!!
    Banned
    Jan 2013
    maryland
    Could the speed sensor be the reason why the car won't start or stay on for long period of time? Location is by the trans correct?
  19. #59 Re: Engine swapping help!!
    speed sensor won't make the car not run
  20. #60 Re: Engine swapping help!!
    Banned
    Jan 2013
    maryland
    Ok I checked and the speed sensor is connected anyway figures lol I'm just tryna figure why the car doesn't start when I pull the fuel pressure regulator line it at least cuts on then shuts off I'm just running out ideas
  1. Top swapping
    By stockGTforlife in forum General Grand Prix Discussion
    Last Post: 09-26-2013, 11:46 AM
  2. swapping
    By coreysGTP in forum Introductions/Noob Questions
    Last Post: 12-28-2012, 10:35 PM
  3. engine swapping question
    By PrixGTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-29-2009, 10:43 PM
  4. Swapping Engine
    By Redgtp1999 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-08-2008, 08:06 PM
