Thread: Engine swapping help!!
Page 1 of 6 123 ... LastLast
Results 1 to 20 of 119
  1. #1 Engine swapping help!!
    Banned
    Jan 2013
    maryland
    Ok guys so I did a engine swap for a few days and my new motor is in but it is having some starting issues... for one the car starts and smokes like f***ing crazy but that's because of the new headers and everything reassembled..any other reasons? Any thing I should into the motor? it starts then shuts off in 5 to 10 secs what could it be? I dont have a o2 extenstion for the headers but splice the connection so that should be good right? spark plugs got changed as soon as first startup to throw away misfires on the plugs but still it won't idle no more for 5 to 10 secs what else could it be? Also as of now I have no steering whatsoever we dropped the cradle because of the rear headers needing to be installed could the cradle being dropped misaline the steering ? Any help would appreciated new motor mods are as follows if it would help thanks
    Xp cam: misfire I know are gonna come no tune
    Double roller
    130# Springs
    Ported Heads
    SD Headers
    EGR Delete
    Machined LIM
    Autolite 103's
    Stock tune as of now
    Sent from my SAMSUNG-SGH-I747 using Tapatalk
  2. #2 Re: Engine swapping help!!
    Try unplugging the maf and see if it'll run. Your rack came disconnected. Hook it back up
  3. #3 Re: Engine swapping help!!
    Banned
    Jan 2013
    maryland
    Ok i'll check for disconnection on the rack unplug the maf thanks dsmuts
  4. #4 Re: Engine swapping help!!
    you mean no steering as the steering wheel spins but not the tires? if so you pulled the shaft off the rack, its under the boot on the drivers side.
    do not spin the wheel around all free like, the clock spring will break in the column.
  5. #5 Re: Engine swapping help!!
    Banned
    Jan 2013
    maryland
    Ok gotcha
  6. #6 Re: Engine swapping help!!
    Banned
    Jan 2013
    maryland
    Fuel pump resistor and or bypass could that be why the car only stays on for a couple seconds? No codes except for misfire because of the cam and egr delete
  7. #7 Re: Engine swapping help!!
    Could be try the bypass
  8. #8 Re: Engine swapping help!!
    Banned
    Jan 2013
    maryland
    Do you know the location? Been looking for it
  9. #9 Re: Engine swapping help!!
    It's the fp relay you have to bend a tab out
  10. #10 Re: Engine swapping help!!
  11. #11 Re: Engine swapping help!!
    Banned
    Jan 2013
    maryland
    Ok thanks guys got lead way today on the car bent 85 tab for high speed mode and the fuel relay and the car turned and stayed in But after I get codes p0121 TPS so I bought a gasket for the throttle body it needed it badly so i replaced throttle body gasket along with recharging my dead battery at the auto shop
    What can it be? It has low fuel could it be no fuel? TPS sensor stopping it from starting? When I start it it stalls now I'm lost now any help would be appreciated thanks guys!!
  12. #12 Re: Engine swapping help!!
    ... osiris94ej's Avatar
    Sep 2012
    Casper Wyoming
    Passlock?
  13. #13 Re: Engine swapping help!!
    Banned
    Jan 2013
    maryland
    Quote Originally Posted by osiris94ej View Post
    Passlock?
    Passlock? could you explain?
  14. #14 Re: Engine swapping help!!
    Sep 2012
    Casper Wyoming
    The Passkey Security. When it dies does the "security" light stay on?
  15. #15 Re: Engine swapping help!!
    Banned
    Jan 2013
    maryland
    Nope that doesn't stay on
  16. #16 Re: Engine swapping help!!
    Sep 2012
    Casper Wyoming
    Check fuel Pressure?
  17. #17 Re: Engine swapping help!!
    Banned
    Jan 2013
    maryland
    Ok just cranked the car and it stay on for 3 secs smh then cut off any other ideas guys? Only codes are p0121 p1406 but those are TPS and EGR code
  18. #18 Re: Engine swapping help!!
    Sep 2012
    Casper Wyoming
    Yea thats not it then. Hard to know without it being in front of me.
  19. #19 Re: Engine swapping help!!
    Banned
    Jan 2013
    maryland
    Ok I'll check that thanks man
  20. #20 Re: Engine swapping help!!
    Banned
    Jan 2013
    maryland
    Fuel pressure is fine any other suggestions? Tryna get it running fellas
  1. Top swapping
    By stockGTforlife in forum General Grand Prix Discussion
    Last Post: 09-26-2013, 11:46 AM
  2. swapping
    By coreysGTP in forum Introductions/Noob Questions
    Last Post: 12-28-2012, 10:35 PM
  3. engine swapping question
    By PrixGTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-29-2009, 10:43 PM
  4. Swapping Engine
    By Redgtp1999 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-08-2008, 08:06 PM
