Ok guys I'll try everything in the morning and thanks for the suggestions just tryna get this beast running
Sent from my SAMSUNG-SGH-I747 using Tapatalk
Ok here's an update: my lower intake manifold is a mainfold that is cut for the gen v so after replacing the manifold with the gen 3, turned the car on and it shuts on after a couple of startups afterwards I started the car and it just starting and shuts off..smh I just running out of ideas.. engine is out of a 2004 Impala SS that went into my 1997 GTP what can be an issue now vaccum line connections could that be it? Anybody have a diagram I know the 97 is different from the other years
you put a l32 in your car? and a gen 5 blower on a gen 3 lim? i think theres a pcv issue you need to deal with being your have to use the TB adapter plate and route the pcv into the TB from your 97.
Nope a l67 with a LIM that's made for a gen v but now a gen 3 lim is on it now
Which blower gen v or gen III? If your using the gen v you need the gen v lim or you'll have sealing issues.
Put the gen 3 blower on the gen 3 lim guys that's taken care of.. what about the vac lines when I didn't hook the vac line to the fuel rail it started then cut off that's the best progress I gotten but when I hook the vac line to the supercharger it had issues
Yea you need a unmodded gen 3 lim if you opened up the one you have for a gen V. You probably have a huge vacuum leak.
Redcompg you might have something there any ideas where it can be i hear it by the throttle body tps sensor code comes on but I deleted it could it be my vaccum lines
Yeah but I'm tryna figure the right lines go to what I forgot to take a pic of my motor before I reassembled it I know dumb mistake any body have a diagram of the vac lines?
Thanks guys predicate this!!!
Could the speed sensor be the reason why the car won't start or stay on for long period of time? Location is by the trans correct?
speed sensor won't make the car not run
Ok I checked and the speed sensor is connected anyway figures lol I'm just tryna figure why the car doesn't start when I pull the fuel pressure regulator line it at least cuts on then shuts off I'm just running out ideas
