Thread: VS cam project almost finished, a couple of questions
Page 6 of 6 FirstFirst ... 456
Results 101 to 116 of 116
  1. #101 Re: VS cam project almost finished, a couple of questions
    Check the fuel rail o rings to those cylinders
  2. #102 Re: VS cam project almost finished, a couple of questions
    Mar 2012
    South Beloit, IL
    They were all replaced, or are you saying to see if they are pinched?
    Sent from my SCH-R530U using Tapatalk 4
  3. #103 Re: VS cam project almost finished, a couple of questions
    No make sure they are seated correctly
  4. #104 Re: VS cam project almost finished, a couple of questions
    I live here. DirtDog's Avatar
    Jun 2012
    Something I learned when I did some work with an impala...I didn't seat the injectors correctly which did cause an issue....and lightly tapped the fuel rail with a rubber mallet. Made them seat easily without damage. Just couldn't get them to pop in properly any other way
  5. #105 Re: VS cam project almost finished, a couple of questions
    What I do is take a rubber mallet and tap the fuel rails in a few different spots to make sure the injectors are all the way in
    Hmmm
    04 Comp G.
  6. #106 Re: VS cam project almost finished, a couple of questions
    Jun 2012
    Quote Originally Posted by DirtDog View Post
    Hmmm
    Well...sh*t
    Ya know what they say....great minds think alike
  7. #107 Re: VS cam project almost finished, a couple of questions
    Mar 2012
    South Beloit, IL
    Lol okay I get the point :P. I went and borrowed a rubber mallet from my neighbor. I've never done this before, is there something I am looking or listening for? Should I do it while the car is running? Should I pull the rails off and reseat them, then tap them in?
  8. #108 Re: VS cam project almost finished, a couple of questions
    if you put the injectors in dry, no lube, take the rail off again, check them, then lube the o rings with oil and slide them back in.
  9. #109 Re: VS cam project almost finished, a couple of questions
    Mar 2012
    South Beloit, IL
    ^ I didn't lube them... Just regular motor oil?
  10. #110 Re: VS cam project almost finished, a couple of questions
    GTX Level Member 97gtpjoe's Avatar
    Jan 2009
    Chandler, Arizona, United States
    Quote Originally Posted by Nchristopherson View Post
    Do it with the car off , fuel pressure in the rails if the car is on. You should be able to see the injectors sit correctly.
    Speed Daddy Headers, Open Cone, 3.4 MPS , AL605s , 180* Stat
  11. #111 Re: VS cam project almost finished, a couple of questions
    if they went in dry, take them off. i bet one rolled, or 2 or 3 of them.
    i use any motor oil, like i pull my dip stick, wipe the stick on my fingers, then lube the o ring with my fingers.
  12. #112 Re: VS cam project almost finished, a couple of questions
    Mar 2012
    South Beloit, IL
    Okay! I'll do this, reseat them, and return with results.
  13. #113 Re: VS cam project almost finished, a couple of questions
    Jan 2009
    "Thats what she said!"
  14. #114 Re: VS cam project almost finished, a couple of questions
    Mar 2012
    South Beloit, IL
    Finally took it for a drive, wow the power is awesome, I barely even got into boost!! I should have done this sooner!
    I took the fuel rails off and lubed up the o-rings with some oil and seated them with the rubber hammer, but the misfire persists.. Now 6 misfires as well, but less often than 1. Absolutely no misfires under load that I can detect or feel.
  15. #115 Re: VS cam project almost finished, a couple of questions
    Does it feel like it's misfiring though?
  16. #116 Re: VS cam project almost finished, a couple of questions
    Mar 2012
    South Beloit, IL
    Woot woot!
    Update!!! I know it's been a long time since this thread was active, but I finally mostly fixed the misfire at idle! Turned out to be a leaky EGR. LTFTs were +16.4 and are now -7 ish.
    So the reason I revived this thread is because my LTFTs are -7 after the cam, headers, and 3.4" drop. Is this normal? It seems normal, the car is much smoother with slight misfire, but nowhere near as bad as it was.
  1. Replies: 20
    Last Post: 12-16-2013, 12:33 PM
  2. Couple questions.
    By PioneerGTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-07-2012, 06:27 PM
  3. couple of questions, couple of issues
    By zero in forum General Tech Discussion
    Last Post: 12-30-2009, 04:48 PM
  4. New Hood Project Started (Finished Pics Added!)
    By Abrasive in forum Visual/Body Modifications
    Last Post: 03-01-2009, 09:12 PM
  5. Girlfriends Cross Stitch project finished
    By GR8racingfool in forum General Tech Discussion
    Last Post: 02-10-2008, 04:12 PM
