Thread: VS cam project almost finished, a couple of questions
Page 4 of 6 FirstFirst ... 23456 LastLast
Results 61 to 80 of 116
  1. #61 Re: VS cam project almost finished, a couple of questions
    Florida
    Upload to photobucket, then copy the IMG code and paste it here.
    Unsure about the check-valve, but that could very easily cause it.
    Along with the oil filter being dry, I'd start taking stuff apart.
  2. #62 Re: VS cam project almost finished, a couple of questions
    Florida
    Hopefully someone who's pulled the filter neck off and rebuilt will chime in.
  3. #63 Re: VS cam project almost finished, a couple of questions
    Mar 2012
    South Beloit, IL
    Looks like the filter adapter is coming off. Dammit.
  4. #64 Re: VS cam project almost finished, a couple of questions
    Mar 2012
    South Beloit, IL
    Picture of the valve
    http://i912.photobucket.com/albums/a...ps8765ff91.jpg
    I don't know what you're particularly looking for in pics to investigate, but I'm sure I have one, lmk.
  5. #65 Re: VS cam project almost finished, a couple of questions
    Donating Users GMR Badass's Avatar
    Apr 2011
    Columbus, OH
    If the plunger and spring are installed backwards it will cause very litte to almost 0 oil pressure. Consider the motor toast.
    Edit....link to pic of how it should be sitting in the housing
    http://intense-racing.com/Merchant2/...de=3800_Engine
    1999 GTP 2dr - Whipple 537whp.....for now
    1998 GTP 4dr - ST2, Cartuning PT61, IC - SOLD
    1999 GTP 2dr - SIX, GenV, Headers, TEP Trans, E85 - SOLD
    1997 GTP 4dr - 3.4, 1.9's, 3" DP, P-log - SOLD
  6. #66 Re: VS cam project almost finished, a couple of questions
    if the filter was dry, and nothing came out when you took the sensor out, you indeed have 0 oil psi.
    that spring and rod just maybe in backwards.
  7. #67 Re: VS cam project almost finished, a couple of questions
    Mar 2012
    South Beloit, IL
    Oh man, you don't really think it would be toast do you? I mean, it was running smoothly, and it has been on maybe a minute cumulatively at idle. The valve was definitely in backwards, I wish I had known that intense had that picture. I suppose I am looking at oil pump damage huh?
  8. #68 Re: VS cam project almost finished, a couple of questions
    Apr 2011
    Columbus, OH
    Cumulatively less than a min you may still have a chance. Install it cottectly, fill up oil filter before install.....and say a little prayer. May luck out but maybe not.....not gonna know until you try.
  9. #69 Re: VS cam project almost finished, a couple of questions
    if it only ran for a minute and no revving the engine it maybe ok. maybe. fix that valve, then take the plugs out and crank it for 15 to 20 seconds, then take the oil filter off to see if oil has gotten to it. if the filters got oil crank it a bunch more cause the engine is really dry.
    then fire her up.
  10. #70 Re: VS cam project almost finished, a couple of questions
    Banned
    Jan 2014
    Washington D.C.
    Why not just pour oil in the filter then spin it on so its already primed?
  11. #71 Re: VS cam project almost finished, a couple of questions
    GT Level Member aligater's Avatar
    london ontario canada
    I think they want to see if the pump fills the filter to prove it has primed. Any other situation then yes fill the filter first.
  12. #72 Re: VS cam project almost finished, a couple of questions
    Banned
    Jan 2014
    Washington D.C.
    hmm good call ^ makes sense.
    If it wasn't revved up i'd like to think it will be ok, only one way to find out though! Good Luck
  13. #73 Re: VS cam project almost finished, a couple of questions
    i always fill a filter when i can. surprised he put it on dry my self.
    but in this case it will prove its pumping oil in a short amount of engine cranking.
  14. #74 Re: VS cam project almost finished, a couple of questions
    Mar 2012
    South Beloit, IL
    Definitely didn't put it on dry, I filled the oil filter up before I put it on.
  15. #75 Re: VS cam project almost finished, a couple of questions
    but its dry now? when you took it off?
  16. #76 Re: VS cam project almost finished, a couple of questions
    Mar 2012
    South Beloit, IL
    Yeah, it's dry now. So that may have given me a little mercy
  17. #77 Re: VS cam project almost finished, a couple of questions
    id think the pump sucked it out, but because the valve was backwards it got no new oil.
    fingers crossed man.
  18. #78 Re: VS cam project almost finished, a couple of questions
    Mar 2012
    South Beloit, IL
    Well, I pulled the neck off, the valve looks okay, but I don't have the shim between the spring and the valve that the intense photo shows. Is this piece absolutely essential?
  19. #79 Re: VS cam project almost finished, a couple of questions
    Feb 2013
    37.295091, -121.930053
    That may be in the psiton... but thats just a guess
    im a cookie again yay me
    please learn to forum better.
    ^^new favorite quote
  20. #80 Re: VS cam project almost finished, a couple of questions
    Apr 2011
    Columbus, OH
    No you shouldn't have that little piece..... that's part of the kit that they sell and is not a stock item.
  1. Replies: 20
    Last Post: 12-16-2013, 12:33 PM
  2. Couple questions.
    By PioneerGTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-07-2012, 06:27 PM
  3. couple of questions, couple of issues
    By zero in forum General Tech Discussion
    Last Post: 12-30-2009, 04:48 PM
  4. New Hood Project Started (Finished Pics Added!)
    By Abrasive in forum Visual/Body Modifications
    Last Post: 03-01-2009, 09:12 PM
  5. Girlfriends Cross Stitch project finished
    By GR8racingfool in forum General Tech Discussion
    Last Post: 02-10-2008, 04:12 PM
