Thread: Vacuum issue
Results 1 to 7 of 7
  1. #1 Vacuum issue
    SE Level Member duswickware's Avatar
    Jan 2014
    mansfield, ohio
    Put a 97 regal motor sc'ed in my 98 gtp everything together jus stuck on how to run the vacuum hoses bein the regal motor has the extra two ports on the blower. What changes need to be made to make this work? A diagram or picture or any help would be appriciated.
    Sent from my ONE_TOUCH_960C using Tapatalk 2
  2. #2 Re: Vacuum issue
  3. #3 Re: Vacuum issue
    Jan 2014
    mansfield, ohio
    Ok we have the fuel pressure regulator line ran straight to the supercharger bypass solinoid and the two ports on front of the blower capped off. Any issue with this, also the alt bracket was changed and motor no longer has evap switch.
  4. #4 Re: Vacuum issue
    that works, so more like a 98+ set up now.
  5. #5 Re: Vacuum issue
    Jan 2014
    mansfield, ohio
    That's what I was looking for jus took a blind stab at it. Thanks for the help. I thought I read something aboutbthe throttle bodies needing changed or does that apply to something else?
  6. #6 Re: Vacuum issue
    TB is fine. you just need to cap off the fat vac line port on the TB that went to the evap.
  7. #7 Re: Vacuum issue
    Jan 2014
    mansfield, ohio
    Ok that's for the help
  1. Evap issue? Vacuum leak?
    By timboku in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-15-2014, 11:22 AM
  2. WTB: MAP sensor vacuum hose or vacuum tees
    By Dschroeter63 in forum Wanted To Buy - Parts
    Last Post: 09-22-2013, 02:23 PM
  3. Issue with A/C no more cold air and sound issue with Shocks
    By ibra0078 in forum General Grand Prix Discussion
    Last Post: 08-09-2013, 08:25 AM
  4. Wheel Bearing Issue or Tire Issue
    By ibra0078 in forum Tires & Wheels
    Last Post: 06-07-2013, 05:12 AM
  5. Throttle Body to vacuum line connector '99 Grand Prix (Also, erratic idle issue)
    By killswitch83 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 09-05-2012, 05:52 PM
