check the fuse box for a blown fuse, the cig lighter fuse also works the obd2 port.
did you take the starter off? maybe the wires are on wrong? you got 3 grounds on the trans bell housing? maybe one broke off? or the loop is loose, we've seen that one before.
as far as the throttle response, you got all the vac lines hooked up correctly?
