Thread: why wont my park ave pcm work in my top swapped gt??
Results 1 to 5 of 5
  1. #1 why wont my park ave pcm work in my top swapped gt??
    SE Level Member Wisconsingrandprix's Avatar
    Aug 2011
    roun here
    fsdfs
  2. #2 Re: why wont my park ave pcm work in my top swapped gt??
    Minnesota
    Because the PCM won't interface with the BCM.
  3. #3 Re: why wont my park ave pcm work in my top swapped gt??
    what he said.
    Alot different between riv/park and grand prix/regal.
  4. #4 Re: why wont my park ave pcm work in my top swapped gt??
    Aug 2011
    roun here
    Thanks ill get have a gtp pcm I forgot about do you think it should run??
  5. #5 Re: why wont my park ave pcm work in my top swapped gt??
    Minnesota
    With a GTP PCM it should as long as you have the correct PCM and correct file.
    Hopefully you also have a L67 or L32 MAP sensor and other correct stuff.
  1. my car wont shift from park without pressing relese button
    By 03limitedgtp in forum General Tech Discussion
    Last Post: 02-12-2012, 12:49 AM
  2. a/c wont work and heat wont go to floor PLEASE HELP!!
    By Brett Muszynski in forum Introductions/Noob Questions
    Last Post: 02-10-2012, 05:43 AM
  3. Top Swapped 06- Wont start
    By Crispix396 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-10-2010, 09:05 PM
  4. Swapped motor, now transmission won't engage Park
    By oldschoolpontiacs in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 06-12-2009, 12:30 AM
