Thread: Polishing and cleaning a supercharger and other parts
Results 1 to 19 of 19
SomeDudeAtHome Polishing and cleaning a... 05-25-2013, 11:22 PM
Fivefingerdeathpunch Re: Polishing and cleaning a... 05-25-2013, 11:24 PM
SomeDudeAtHome Re: Polishing and cleaning a... 05-26-2013, 07:20 AM
SomeDudeAtHome Re: Polishing and cleaning a... 05-29-2013, 11:48 AM
REDCRAPGP Re: Polishing and cleaning a... 05-29-2013, 12:27 PM
coolone Re: Polishing and cleaning a... 05-29-2013, 04:43 PM
SomeDudeAtHome Re: Polishing and cleaning a... 05-29-2013, 09:34 PM
Scottydoggs Re: Polishing and cleaning a... 05-29-2013, 09:37 PM
REDCRAPGP Re: Polishing and cleaning a... 05-29-2013, 11:02 PM
machinegunsquid Re: Polishing and cleaning a... 05-29-2013, 11:35 PM
sco77 Re: Polishing and cleaning a... 05-30-2013, 05:40 AM
FriboRage Re: Polishing and cleaning a... 05-31-2013, 01:34 AM
REDCRAPGP Re: Polishing and cleaning a... 05-30-2013, 11:21 AM
88formula Re: Polishing and cleaning a... 05-30-2013, 03:24 PM
Jevik Re: Polishing and cleaning a... 05-30-2013, 05:12 PM
DanPrixGTP Re: Polishing and cleaning a... 05-30-2013, 05:14 PM
SomeDudeAtHome Re: Polishing and cleaning a... 05-30-2013, 06:29 PM
sco77 Re: Polishing and cleaning a... 05-30-2013, 08:05 PM
REDCRAPGP Re: Polishing and cleaning a... 05-31-2013, 01:10 PM
  1. #1 Polishing and cleaning a supercharger and other parts
    GTX Level Member SomeDudeAtHome's Avatar
    Buffalo, NY
    So I just picked up a gen V, LIM, heads, and throttle body. They'll be sitting for a while before I get around to using them. Right now they have the usual amount of gunk on them from just being pulled from a motor. Since they'll be sitting a while I'd like to get them all cleaned and put away nicely so they stay in good condition and don't stink the garage up. Basically the only thing that really needs a cleaning is the heads. How would I do this and is it even good for them? I don't want to clean the rotors of the sc or anything.
    Now my other question. What's the best way to polish a supercharger? I have a dremel with all the polishing bits and plan on using that. Is there a certain technique that should be used? Will I need to take the rotors out or should they be ok since the outlet will be down?
  2. #2 Re: Polishing and cleaning a supercharger and other parts
    Parts cleaner for the heads, if you want to remove all the oil.
  3. #3 Re: Polishing and cleaning a supercharger and other parts
    Buffalo, NY
    So put the parts cleaner on them and then spray them with the hose?
  4. #4 Re: Polishing and cleaning a supercharger and other parts
    Buffalo, NY
    bump! Any advice for polishing?
  5. #5 Re: Polishing and cleaning a supercharger and other parts
    Quote Originally Posted by SomeDudeAtHome View Post
    Yup send them to gr8racingfool let him take care of you
    04 Comp G.
  6. #6 Re: Polishing and cleaning a supercharger and other parts
    Nov 2011
    NY
    Reptile used to polish the S/C's too... Don't know if he does anymore, but worth a shot.
    Otherwise, it's not as easy as you might think to get a good finish product. Bits only get you do far, then you've got to go down to fine abrasive polishing compounds too. I'd pay someone who has experience, lol... If I wanted it polished.
    Good luck!
  7. #7 Re: Polishing and cleaning a supercharger and other parts
    Buffalo, NY
    So I pm'd gr8racingfool and it is a lot more work than I want to take on so it's staying the way it is. thanks for the help everyone
  8. #8 Re: Polishing and cleaning a supercharger and other parts
    paint always works, cheap and easy.
    maybe polish the snout, as its smooth already unlike the case.
  9. #9 Re: Polishing and cleaning a supercharger and other parts
    This. Polish is awesome if you can afford to have someone else do it. Wouldn't be something I'd do myself takes way to much time. Paints cheap and easy to do
    04 Comp G.
  10. #10 Re: Polishing and cleaning a supercharger and other parts
    Florida
    Get it powdercoated chrome??
    Any bare metal surface will rust after being cleaned and exposed to air/moisture.
    After you clean the heads, spray some oil all over them to prevent them from rusting.
  11. #11 Re: Polishing and cleaning a supercharger and other parts
    SE Level Member sco77's Avatar
    MD
    My advise is to send it out to Farnsworth / gr8racingfool and pay for polishing.. Trust me its well worth it and after you start doing it yourself you will hate yourself for even attempting it. You will end up spending a lot of money and a LOOTT of time doing it yourself. As far as tools you will need a die grinder, 100s of sanding rolls, grinding bits, buffer wheels with greaseless compounds, many high grits of wet sand paper, etc...
    Here is a blower housing I polished myself, if I could go back I would have just had the entire thing sent out, in the end it probably wouldn't have costed me more and would likely have turned out better...
    Current progress:
    Sent from Android.
    98 GTP - Retired
    86 Fiero GT - L67 | VS Cam | Polished GenV | Headers to 3" Catback to dual/dual Tips | 42.5# | N*
  12. #12 Re: Polishing and cleaning a supercharger and other parts
    Pennsylvania
    Quote Originally Posted by sco77 View Post
    Current progress:
    Sent from Android.
    Dear lord, this is beautiful. How much would a job like this cost from someone, you should do a write up in the how-to section... even if it's just your process and materials..
    Sport Edition Kv5 18x8
  13. #13 Re: Polishing and cleaning a supercharger and other parts
    Shiny!
    04 Comp G.
  14. #14 Re: Polishing and cleaning a supercharger and other parts
    GT Level Member 88formula's Avatar
    Oct 2012
    West Branch, MI
    How much do people usually charge to polish a blower like that? I know a while back I PMed Reptile and never got a response.
    1997 Regal GS, L26 N/A block, 'Reptile' Ported Gen 3 Blower w/3.5 pulley, VS cam, K&N Open Cone, Speed Daddy Headers, 3" cat and res, Dual 2.5" Dynomax mufflers w/C6 Corvette tips. PLX Wideband, Custom Dyno Tuned By Jeff @ Engineered Performance. Lucerne 17's, F-Body Brakes.
  15. #15 Re: Polishing and cleaning a supercharger and other parts
    Johnstown, NY
    Wow! That's shiny.. How much did that cost to get so shiny?
    98 Red Coupe Grand Prix GTP : 180* T-stat, U-Bend delete, NGK TR55's, SLP Catback
    My Ride: http://www.grandprixforums.net/jevik...upe-73301.html
    A must read for modding: http://www.grandprixforums.net/safel...0-a-67580.html
  16. #16 Re: Polishing and cleaning a supercharger and other parts
    Moderator DanPrixGTP's Avatar
    Jun 2011
    Grand Rapids, Michigan
    That looks fabulous.
  17. #17 Re: Polishing and cleaning a supercharger and other parts
    Buffalo, NY
    Would it be better to just leave them dirty then?
    And sco77 that looks awesome. It's a bigger project than I want now though so I'm not gonna bother.
  18. #18 Re: Polishing and cleaning a supercharger and other parts
    MD
    It WONT rust, it's aluminum!!! It will have to be maintained with touchup polishing or it will loss it's shine and eventually build up some corrosion (but polished aluminum doesn't corrode the same as cast aluminum, don't know why but it doesn't), which could become nearly impossible with a daily driver. As good as polished blower looks, for a daily driver I would maybe go the paint / powdercoat method if you want it to look nice and be easier to clean.
    98 GTP - Retired
  19. #19 Re: Polishing and cleaning a supercharger and other parts
    Probably would cost your first unborn child I bet
    04 Comp G.
  1. Cleaning Parts
    By tdm571 in forum Engine
    Last Post: 04-26-2012, 07:19 AM
  2. HELP ASAP!! Port and Polishing supercharger
    By GP_Kid18 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-10-2011, 07:15 AM
  3. Supercharger snout and case cleaning
    By GOTIT4CHEAP16 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-24-2011, 05:05 PM
  4. polishing supercharger
    By fremmy182 in forum General Tech Discussion
    Last Post: 12-17-2010, 09:45 PM
  5. Cleaning Gen V Supercharger out
    By geforcextreme in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-14-2010, 05:30 PM
