Thread: engine swap
Results 1 to 10 of 10
  1. #1 engine swap
    Texas
    I have a 1997 Grand prix gtp. I was wondering would a 97 buick riviera supercharged engine bolt right in? I saw that the motor mount where the serpintine belt is in a different position. The engine it self looked pretty much the same?
  2. #2 Re: engine swap
    St. Louis
    Engine should be the same. Just swap over any of the GP specific brackets/mounts and fire it up.
  3. #3 Re: engine swap
    GTP Level Member BlackGT97's Avatar
    Jul 2011
    Michigan
    should be pretty basic..Im in the middle of a swap also. Good luck!!!
    1997 Grand prix GT Black Coupe- The beater
    1998 Grand prix GT Black coupe- Top swapped, XP cam
    2008 Grand prix Midnight blue- The slow but nice car
    1999 Chevrolet Silverado red ext. Cab
  4. #4 Re: engine swap
    Texas
    Thanks for the info. would yall recommend changing any gaskets or what not since the other engine is coming out of a car from the junk yard.
  5. #5 Re: engine swap
    Rear main and oil pan gasket for sure.
    And if the intake gaskets have not been done yet, those are a must too, you don't want those to fail and have coolant dump into the motor and spin a few bearings.
  6. #6 Re: engine swap
    St. Louis
    FFDP, you mean the rear cover, or rear main? I always thought it was the cover that was the issue.
    OP- I would also replace the valve cover gaskets and bolt grommets while out. Oh, and if you notice that the rack is leaking or worn now would be the perfect time to install a new rack since there will be nothing in the way. Just step into the bay and a few bolts and lines later it's out and back in. Wished I'd done mine when I had my motor out.
  7. #7 Re: engine swap
    Rear cover. I've yet to see a rear main leak. Cover...always leaking! Use a little locktite on the bolts too. They are such a low torque..you need something to keep them from backing out.
    It'll drop right in. Things to swap:
    Rear exhaust manifold.
    Pull that front bracket (mount) and fill in the holes with whatever is in your gp motor holes.
    Swap the coil pack bracket from your gtp on it
    Swap evap if it's different (if not 97 to 97, it'll be different)
    Swap alt bracket if it's different
    SWap AC brackets
    That's it in a nutshell.
  8. #8 Re: engine swap
    Rear main, rear cover.... same thing.
  9. #9 Re: engine swap
    In my eyes, I see two seperate gaskets. The rear engine cover is one and the rear main is a second.
    A rear engine cover gasket will appear to look like an oil pan gasket is bad. Yet no matter how many times you replace it.. you can't stop the leak. A rear main should show up with a moist flexplate. As the oil seeps out, it's on the crank and then the flex and it will sling it all over inside the bell houseing.
  10. #10 Re: engine swap
    Texas
    Ok so new up date. I ended up getting an engine out of a 2004 impala ss. The guy told me it was the same engine. Please tell me the guy is right. It looked the same to me? Should I still replace the rear main seal? The engine supposedly has 59K miles on it. I was planning on changing only the valve cover gaskets and the oil pan gasket.
  1. Engine swap or top swap
    By 06PONTGP in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-27-2013, 12:01 AM
  2. Replies: 15
    Last Post: 01-25-2013, 03:05 PM
  3. Engine Starts then dies after L36 Engine Swap! Help needed!
    By millertime2800 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-18-2012, 10:50 PM
  4. engine swap 3800 sc to same but not burned engine
    By roger7 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-10-2011, 01:59 PM
  5. Spartans Engine Swap (Engine Damage Pics on Front Page!)
    Last Post: 05-05-2010, 12:50 AM
