Thread: Engine swap or top swap
Results 1 to 20 of 22
  1. #1 Engine swap or top swap
    Northeast Ohio
    ok so i have a 2006 grand prix n/a l26 with 118K well i can get a whole l32 with 96k for about 1000 or a gen v top swap for around 800....if im not mistaken i would need a engine harness for both ways and a pcm. I was curious on what everyone else thought on which is the better way
  2. #2 Re: Engine swap or top swap
    GT Level Member 01GrandPrixTURBOGT's Avatar
    Dec 2011
    Decatur
    I chose the top swap route and have problems I thought were major but ended up being simple so far. But I'd rather have the higher compression.
  3. #3 Re: Engine swap or top swap
    Northeast Ohio
    what were the issues and was the other harness easy to swap out
  4. #4 Re: Engine swap or top swap
    Jan 2012
    Philadelphia
    I have a topswap for sale but its for a GenIII but I can make you a deal on it with out the GenIII. So you will have all of the other parts to topswap it you would just need to buy a GenV and if you go that route your topswap will be way cheaper then $800. Just throwing it out there, Id rather topswap because then you have a high compression block already.
  5. #5 Re: Engine swap or top swap
    Northeast Ohio
    what you thinking because you cant find a gen v and lim for under 300 then plus gaskets
  6. #6 Re: Engine swap or top swap
    Jan 2012
    Philadelphia
    Quote Originally Posted by 06PONTGP View Post
    PM me and we'll talk about working something out, I have a GenV LIM I can throw in
  7. #7 Re: Engine swap or top swap
    new britain, ct
    people always talk about high compression etc.
    but will the rods be able to handle the boost? aren't they weaker in the N/A cars?
    07 Black GXP.
  8. #8 Re: Engine swap or top swap
    Northeast Ohio
    not in 05+ if im not mistaken all motors have the better connecting rod
  9. #9 Re: Engine swap or top swap
    Dec 2011
    Decatur
    My issue was a misfire but it ended up being plugs which I had bought all brand new including ignition. So I put my old ones in AMD problem soved so far. The l36 block is plenty strong enough if tuned right.
  10. #10 Re: Engine swap or top swap
    if given a choice again after what i've done (both ways), build the motor outside of the car while you drive it and take your time. then swap the entire motor. it's a whole lot less hassle than doing a top swap in the car.
    Ohio
    This... All of this.
    Don't top swap your car. You have Le ****ty rods.
  12. #12 Re: Engine swap or top swap
    May 2008
    Schuyler, NE
    Top swap it. L26 rods don't have issues until you start making a lot of power.
  13. #13 Re: Engine swap or top swap
    Yup ^^^ and the vast majority of us will never make that much power in our cars to matter anyway.
  14. #14 Re: Engine swap or top swap
    it's not that i wouldnt trust the rods in the L26, it's that it's simply easier doing a full motor swap and it's easier to work on the motor outside of the car, by far.
  15. #15 Re: Engine swap or top swap
    May 2008
    Schuyler, NE
    Then pull the motor and do the swap. High compression>Low compression with the M90.
  16. #16 Re: Engine swap or top swap
    depends if you're gonna run out of headroom to run more boost or not. if you're gonna be down in the 2.6 pulley range on the L67/32 then for sure go high compression. i always like leaning towards more boost, though so i like the 'low' compression blocks.
  17. #17 Re: Engine swap or top swap
    May 2008
    Schuyler, NE
    It's because the rod cap bolts are smaller and break easier. The L36 rod cap bolts are a little bigger in diameter.
    Even on the stock pulley, the higher compression bottom end will make more power.
  18. #18 Re: Engine swap or top swap
    Northeast Ohio
    i look at this in a few ways one,the engine swap is in my eyes easier......but the top swap makes a little more power, the l32 has 96k mine 118k....but from what i read in 05+ the l26 get the powdered metal rod just like the l32 and the difference at stock between the 2 set ups is 5%....not to worried about it im not going super crazy maybe a cam with either swap exhaust and pulley drop prolly the most ill do not looking to buy stock in gm for 4t65hds
    Mercer, Pa
    Running L26 bottom end with supercharger heads, VS cam and gen 5. Been running this way for a year, lots of power! I don't beat it to death but I'm not 20 or 30 something anymore.
  20. #20 Re: Engine swap or top swap
    Northeast Ohio
    looks like im leaning toward a l32 i can get it with way less miles and for the same money seems like a no brainer to me just add a hd conversion and off i go.....but if i recall correctly i will need the engine obviously engine harness and pcm? dont think im missing anything, if any one hase done this before with their 04+ and have tricks or tips to make this smooth it would be very much appreciated
  1. Engine Starts then dies after L36 Engine Swap! Help needed!
    By millertime2800 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-18-2012, 10:50 PM
  2. Fuel gauge dosnt work after wireing harness swap and motor swap
    By guimond47 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-02-2011, 06:01 PM
  3. engine swap 3800 sc to same but not burned engine
    By roger7 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-10-2011, 01:59 PM
  4. Spartans Engine Swap (Engine Damage Pics on Front Page!)
    Last Post: 05-05-2010, 12:50 AM
  5. Engine swap
    By BankRupt in forum Off Topic Discussion
    Last Post: 07-19-2008, 11:06 AM
