Thread: VS Cam Build.
Results 21 to 40 of 62
  1. #21 Re: VS Cam Build.
    GTP Level Member GTP89's Avatar
    Buena Park Ca
    Quote Originally Posted by Anthony Smith View Post
    L76 springs and retainers are awesome for small cams. I shift mine at 6200, rev limit at 6300 and they never float or give me any grief. All for under $70 right from the dealer. As stated though if you already have something else that will work just as good stick with it. As for injectors if you have any thoughts about going e85 I wouldn't waste my time with 42's. you will need a tune anyway so why not jump right to 60's for an extra $20-40 and be done with it.
    Yeah unfortunately I have the springs already.
    Injectors aren't the issue it's stations and being my dd
    i have two sets of 60s one new and the other used I don't have 42 it's a hard decision honestly I would love e85 but seems like that would have to wait for my xpz build
    If You Cant Hear The Whine You're Too Far Behind...
  2. #22 Re: VS Cam Build.
    Mullet Member Wotgtp's Avatar
    Connecticut
    Dude if you have two pairs of 60's, throw the other in the vs build. I had 60's lying around because I was going to go turbo, but I scrapped the build. When I did my NIC build, I bought 42's, thinking 60's would give me issues. You can tune 60's on a "mild" setup like what you're doing. If anything it's a muh better injector and better spray pattern. I know people bash the guy, but Nick (snowflake) tuned 60's on his N/A 3.8 because he was going to turbo it a couple weeks later, and he needed to the the intake manifold swap to convert from S/C to N/A. He said he had no drivability issues and gas mileage was about the same.
  3. #23 Re: VS Cam Build.
    SE Level Member mikes01gtp's Avatar
    Mar 2013
    Alachua, FL
    Sorry to break in to your tread but dude I'am looking for 60 to 90 injectors for E-85 any of you want to turn them loose $ ?
  4. #24 Re: VS Cam Build.
    May 2008
    Schuyler, NE
    Looks like most of the misinformation have been fixed in this thread.
    Except, don't use L76 springs. They are not rated for the lift the VS cam on stock rockers will make.
  5. #25 Re: VS Cam Build.
    Oct 2012
    West Springfield
    L76 springs are rated to .530 lift, they don't bind until about .580.
  6. #26 Re: VS Cam Build.
    May 2008
    Schuyler, NE
    Quote Originally Posted by Phil99gp View Post
    And VS cam lift with stock rockers is somewhere around .544. Hence why they should not be run with that cam.
  7. #27 Re: VS Cam Build.
    Oct 2012
    West Springfield
    I thought the lift on the vs was .512 on the intake side and less on the exhaust. Is there a new grind?
  8. #28 Re: VS Cam Build.
    May 2008
    Schuyler, NE
    No, that is with 1.6 ratio rockers though.
  9. #29 Re: VS Cam Build.
    Oct 2012
    West Springfield
    If you're worried about deflection, you can run an LS9 spring, which is essentially the same as the L76, rated for .570 though.
    Thyere like $2.80 each from GM.
  10. #30 Re: VS Cam Build.
    Buena Park Ca
    Quote Originally Posted by Wotgtp View Post
    I did not know this I thought it would be too much of a injector to use on a vs cam and mileage would drop a good amount over 42s.
    In that case I think I might get two different tunes one to run on 91oct and other on e85 with the same injector if it isn't too much of a hassle.
  11. #31 Re: VS Cam Build.
    Buena Park Ca
    Quote Originally Posted by mikes01gtp View Post
    Sorry for the reason why I had them and not sold them is because I still can't decide what fuel to go with but now seems like I can use my 60s for 91oct which I didn't know
  12. #32 Re: VS Cam Build.
    Apr 2011
    Vassar, Mi
    I run my comp cam with 512/512 on L76 springs and stock rockers, it is perfectly fine after 20k....
    As long as it is tuned properly injector sizing shouldnt have any effect on fuel mileage.
    1999 GTP Coupe ------ Comp Cam 76-802-9, 2.7" pulley, S2IC, N*, FWI, SD Headers, DHP Tune, Built trans (single 3.29s, 300m), Magnaflow Catback, 60#injectors, E85, MT ET Street DR's, Fbody brakes, PRJ pump/rails. 302whp/328ft-lbs.......12.41@110mph
  13. #33 Re: VS Cam Build.
    May 2008
    Schuyler, NE
    I don't care about deflection.
  14. #34 Re: VS Cam Build.
    May 2008
    Schuyler, NE
    I know people do it....it's not something I would recommend though.
    Just like myself running a stock timing chain with 20k miles on it...10k using LS6 springs, and 10k using 130# springs. I wouldn't recommend that to anyone.
  15. #35 Re: VS Cam Build.
    Oct 2012
    West Springfield
    Maybe some detail, article, or documents of some kind to illustrate your point would help people to understand why a spring that's more than capable (infact nearly ideal) of handling a vs cam shouldn't be used.
    These one liners aren't helping anyone.
  16. #36 Re: VS Cam Build.
    May 2008
    Schuyler, NE
    Read what I've already posted. Post #26.
  17. #37 Re: VS Cam Build.
    Buena Park Ca
    As far as the Trans go say I do get to 350whp max out if the setup I plan.
    Will a shift kit harden 4th be enough I was planning on using the sonnax upgraded valve body but idk if there is stages of this there is a guy selling it on the forums.
  18. #38 Re: VS Cam Build.
    GT Level Member Seachicken's Avatar
    Jan 2013
    Edmonton, Alberta
    isnt stock 1.6?
    206/216 at .050"
    Intake Lift .320" (.512" lift at 1.6:1 rocker ratio)
    Exhaust Lift .317" (.507" lift at 1.6:1 rocker ratio)
    115 LSA
    Comp Cams - VS Cam #COMP-3311/3303-115+2-VS
    06 Gxp, Bermuda Blue
    82 K5, Black on 35's
  19. #39 Re: VS Cam Build.
    May 2008
    Schuyler, NE
    Quote Originally Posted by GTP89 View Post
    No, you will probably want an input shaft and 7/8" chain as well.
  20. #40 Re: VS Cam Build.
    May 2008
    Schuyler, NE
    Quote Originally Posted by Seachicken View Post
    isnt stock 1.6?
    206/216 at .050"
    115 LSA
    No. Stock rockers are not a fixed ratio. The higher the lift, the higher the ratio.
  1. ZZP XPZ Build
    By bbptech in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-25-2017, 09:40 PM
  2. First ET's with the new build
    By Anthony Smith in forum Track Sessions and Kills
    Last Post: 06-07-2014, 04:16 PM
  3. CSC Build
    By DoubleBlown in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-07-2013, 04:05 PM
  4. Too Slow, Time for a build (GEN V/N*/L32 Lim build)
    By AmericanSoldier in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-13-2012, 01:54 PM
  5. My new build
    By siLversLeigh in forum Members Rides
    Last Post: 02-23-2011, 02:04 AM
