Thread: Car runs bad HELP
Results 1 to 12 of 12
  1. #1 Car runs bad HELP
    Feb 2013
    Canada
    I did the valve cover, intake, and supercharger gasket along with a new thermostat on my 99 gtp
    after i put it all together the car has been running poorly, when i start it then turn it off theres a hiss, i found that air is coming from or going in, at the SC bypass actuator
    Google Image Result for http://ww2.justanswer.com/uploads/superbovine/2010-04-04_183929_Untitled.jpg
    and heres a pic of the part
    http://thumbs4.ebaystatic.com/d/l225...wwwtHaEqJA.jpg
    its coming from where the little rod underneath goes into it.
    is that normal or is that the problem? the rod can move up and down in it but when i move it it does nothing. what's the rod supposed to do?
    Help?
  2. #2 Re: Car runs bad HELP
    that rod should move when you jump on the gas. in park a quick short rev it should move on its own. if not, then you should change it. as well if it dont move on its own.
    also make sure a vac line to it is not cracked, i redid most of my vac lines when i did my lim due to all the rubber ends breaking when i took them off.
    if theres a leak to the actuator or boost solenoid it wont work.
  3. #3 Re: Car runs bad HELP
    Feb 2013
    Canada
    There's air coming in(or) going out of where the rod goes into the actuator, is this supposed to happen or is that where my leak is?
  4. #4 Re: Car runs bad HELP
    not supposed to leak.
    sounds like you need a new one if all the vac lines are good.
  5. #5 Re: Car runs bad HELP
    Feb 2013
    Canada
    That's the problem then, Thanks!
  6. #6 Re: Car runs bad HELP
    1 Thread per topic guy.
    Don't make 3 threads about 1 question, it won't help you get your answers faster, research and searching can normally find anything you are looking for if you try hard enough.
    I closed your other threads.
  7. #7 Re: Car runs bad HELP
    Jul 2013
    San Bernardino,Ca
    would a bad supercharger bypass actuator cause a P0171 code?
  8. #8 Re: Car runs bad HELP
    give the code description a good read. more then likely a vac leak, or a bad o2 sensor. OBD-II DTC: P0171 System Too Lean (Bank 1)
  9. #9 Re: Car runs bad HELP
    Jul 2013
    San Bernardino,Ca
    when I have the car running and move the actuator by hand it sounds like I hear a vacuum leak? is that possible?
  10. #10 Re: Car runs bad HELP
    you shouldn't.
  11. #11 Re: Car runs bad HELP
    Jul 2013
    San Bernardino,Ca
    well the sound changes when i wiggle it "just a little bit" lol
  12. #12 Re: Car runs bad HELP
    Feb 2013
    37.295091, -121.930053
    why didnt you remove them from the site FFDP?
    im a cookie again yay me
    please learn to forum better.
    ^^new favorite quote
  1. Car runs hot when ac is off.
    By DreamerGT in forum General Tech Discussion
    Last Post: 10-13-2012, 02:56 AM
  2. Starts, runs fine for a week, then won't start for 5 minutes, then starts and runs...
    By Summit670 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-26-2012, 05:33 PM
  3. This guy says he runs mid 12's...
    By milo033 in forum General Grand Prix Discussion
    Last Post: 03-30-2012, 10:48 AM
  4. Yay my GTP runs
    By KwazrollinZ28GTP in forum Off Topic Discussion
    Last Post: 10-01-2010, 03:23 AM
  5. car runs hot?
    By chuy09 in forum General Tech Discussion
    Last Post: 05-31-2009, 08:36 AM
