Thread: car runs hot?
Results 1 to 7 of 7
  1. #1 car runs hot?
    El Paso, TX
    idk if its normal but the needle is a lil bit above the half way mark on the dashboard and it warms up fast. I noticed the fan wasnt on when i opened the hood but it does turn on when I turn on the AC.
  2. #2 Re: car runs hot?
    El Paso, TX
    and what kind of coolant should I use? considering the whole dex-cool bad for us law suit thing
  3. #3 Re: car runs hot?
    Go get it flushed somewhere or DIY it. Use the green stuff IMO. Dex-cool blows. If you have a stock temp T-Stat it might climb past the middle mark too since it is getting hotter outside. Go to a local auto parts store and get a 180* or 160* T-Stat if you are worried.
  4. #4 Re: car runs hot?
    El Paso, TX
    thanx i'll go do that
  5. #5 Re: car runs hot?
    you cant use a colder thermostat effectively without changing your fan turn on points to be lower. i run a 180* thermostat all year long.
  6. #6 Re: car runs hot?
    PA
    X2.
    If you have a stock car and no tuned PCM, a lower temp t-stat isn't really going to do any good other than lowering your MPG and making it run worse. Stick with a stock t-stat and just get your coolant system flushed and re-filled with new coolant.
    2001 GSE
  7. #7 Re: car runs hot?
    i pay to play badbrad's Avatar
    Dec 2008
    hueytown, alabama
    also, make sure the air is bleed ut of the system.
  1. Need some help folks, car starts, runs, then dies
    By SyntheticShield in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-14-2010, 05:48 AM
  2. car starts, runs for a second, then dies
    By 2000GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-22-2009, 11:34 AM
  3. oil light on and runs rough
    By 513yj in forum 3.1L V6 (LHO/LG8)
    Last Post: 02-20-2009, 09:20 PM
  4. Blower motor runs but no/little air comes out.
    By bradford82 in forum General Tech Discussion
    Last Post: 01-13-2009, 05:58 PM
  5. WTF new Infiniti SUV runs 13.5's!!!
    By Smokin2000gtp in forum Off Topic Discussion
    Last Post: 11-23-2008, 07:02 PM
