that rod should move when you jump on the gas. in park a quick short rev it should move on its own. if not, then you should change it. as well if it dont move on its own.
also make sure a vac line to it is not cracked, i redid most of my vac lines when i did my lim due to all the rubber ends breaking when i took them off.
if theres a leak to the actuator or boost solenoid it wont work.
There's air coming in(or) going out of where the rod goes into the actuator, is this supposed to happen or is that where my leak is?
