Thread: Car runs hot when ac is off.
Results 1 to 16 of 16
  1. #1 Car runs hot when ac is off.
    Jan 2012
    Austin,tx
    With the ac on everything is fine, any idea on where to start looking to fix this? thanks
    06 Grand Prix GT stock, 02 Mustang GT far from stock
  2. #2 Re: Car runs hot when ac is off.
    when the a/c is on both fans are also on full time.
    with that being said, have you checked your coolant level, and re bleed the system? if your low on coolant is went somewhere.......
  3. #3 Re: Car runs hot when ac is off.
    Jan 2012
    Austin,tx
    Yeah the coolant seems to be level.
  4. #4 Re: Car runs hot when ac is off.
    okay, its level.
    But have you bleed the cooling system yet?
  5. #5 Re: Car runs hot when ac is off.
    Jan 2012
    Austin,tx
    no i havent, how would i do this?
  6. #6 Re: Car runs hot when ac is off.
    When the car is warmed up to temp there is a bleeder valve on top of the thermostat housing. Crack that open until a steady stream comes out of it.
  7. #7 Re: Car runs hot when ac is off.
    Jan 2012
    Austin,tx
    ok cool, i try that and report back. thanks
  8. #8 Re: Car runs hot when ac is off.
    Jan 2012
    Austin,tx
    ok i open it and a stream come out, but the fans didnt kick on and the temp. started to rise.
  9. #9 Re: Car runs hot when ac is off.
    GT Level Member Tony Mendez's Avatar
    Aug 2012
    Somerset WI
    low speed fan not coming on
  10. #10 Re: Car runs hot when ac is off.
    Jan 2012
    Austin,tx
    no not at all
  11. #11 Re: Car runs hot when ac is off.
    Define hot.
    I bet its not even reaching 210ยบ, fans dont even kick on till 212 and 226.
    Do you have a scanner that you're reading off or are you thinking that halfway on the temp gauge is too hot.
  12. #12 Re: Car runs hot when ac is off.
    GT Level Member popeyenate's Avatar
    Jan 2009
    san diego
    i have been having same issues, but now when i turn on the A/C, the fans dont even kick on. what could this be? Computer going out? Relays look fine, havent taken power and ohm meter to them yet...will do that tonight
  13. #13 Re: Car runs hot when ac is off.
    Jan 2009
    san diego
    ok, so a/c on, fans dont spin. the relays for fans (cooling fans, cooling fan 1 and cooling fan 2) are all good, the fuses are all good as well. is there a "drop resistor" on these newer cars like some of the old school ones? or is my computer shot? could be fans...going to check now.
  14. #14 Re: Car runs hot when ac is off.
    Jan 2009
    san diego
    so no drop resistor, pulled sensor output off that feeds ECM and fans kick on...wth is the issue? i am starting to hate this car...a decade it has been fine, til now
  15. #15 Re: Car runs hot when ac is off.
    Quote Originally Posted by popeyenate View Post
    you pulled the plug in the sensor under the t stat? that would be your engine water temp sensor.
  16. #16 Re: Car runs hot when ac is off.
    Jan 2009
    san diego
    that is the hard way to do it, but yet. i pulled it just above on the wire, right in front of the forward set of injectors...same thing, less of a pain to deal with...fans are on. plugged in, fans off. turns out my a/c was so damned low on refer it didnt want to work...at all. now its NICE AND COLD inside and fans work, how they were supposed to.
  1. Starts, runs fine for a week, then won't start for 5 minutes, then starts and runs...
    By Summit670 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-26-2012, 05:33 PM
  2. This guy says he runs mid 12's...
    By milo033 in forum General Grand Prix Discussion
    Last Post: 03-30-2012, 10:48 AM
  3. Yay my GTP runs
    By KwazrollinZ28GTP in forum Off Topic Discussion
    Last Post: 10-01-2010, 03:23 AM
  4. car runs hot?
    By chuy09 in forum General Tech Discussion
    Last Post: 05-31-2009, 08:36 AM
