Thread: Top swap not making power! Help
Page 3 of 6 FirstFirst 12345 ... LastLast
Results 41 to 60 of 103
  1. #41 Re: Top swap not making power! Help
    GT Level Member Steven Monteith's Avatar
    May 2012
    Phoenix, AZ
    Ok I'll have to check it out tomorrow when I go to the shop. I'll take some closer pics of everything. So these lines not being connected correctly can cause me to not get any power from the supercharger AND xp cam?
  2. #42 Re: Top swap not making power! Help
    not sure, but either way it dont look right at all. and that alone can hurt performance.
    how does it idle, smooth? or just the normal cam chop?
  3. #43 Re: Top swap not making power! Help
    GTX Level Member 97gtsc's Avatar
    Jul 2008
    Livonia MI.
    It looks like the fpr is gettn vac from the wrong place?
  4. #44 Re: Top swap not making power! Help
    May 2012
    Phoenix, AZ
    Ok I see the T and the line going underneath the snout. I'll have to check it out tomorrow when I go to the shop and I'll take some pics. So these lines can cause me to not get any power out of the supercharger? And more so no power out of the xp cam?
  5. #45 Re: Top swap not making power! Help
    May 2012
    Phoenix, AZ
    Cam chop
  6. #46 Re: Top swap not making power! Help
    May 2012
    Phoenix, AZ
    Quote Originally Posted by 97gtsc View Post
    Can you explain please
  7. #47 Re: Top swap not making power! Help
    May 2012
    Phoenix, AZ
    Guy from the dyno just called and told me he put on a belt that was ½ inch smaller and rerouted a hose, not sure which one and blocked off the vaccum side of the blower and now has 7lbs of boost with a little spike of 9lbs. 16 degrees of timing. Putting down 240ish HP and 230ish torque. Progress but still low power. Since the vacuum side Is blocked, does that mean the BBV is bad?
  8. #48 Re: Top swap not making power! Help
    heres some pics of the vac lines, i just redid mine today.
    this was the stock line. the left side went to the T under the sc snout.
  9. #49 Re: Top swap not making power! Help
    Ok stop guys he has a 97 blower with the vac tree so he does not need that line going under the snout to the T. And from looking at the pic the vac tree isnt even hooked up to anything, that might be your problem.
    97-98 with vac tree
    98+ without vac tree
  10. #50 Re: Top swap not making power! Help
    May 2012
    Phoenix, AZ
    I'll take some pics a little later when I get home. The guy from the dyno shop changed some of the hoses and bypassed some things. Im at school right now. I just picked it up from the dyno shop.
  11. #51 Re: Top swap not making power! Help
    May 2012
    Phoenix, AZ
    [QUOTE=slick2500;919100]Ok stop guys he has a 97 blower with the vac tree so he does not need that line going under the snout to the T. And from looking at the pic the vac tree isnt even hooked up to anything, that might be your problem.
    97-98 with vac tree
    Is the vac tree on top of the supercharger that has 3 spouts coming out of it?
  12. #52 Re: Top swap not making power! Help
    Yeah its in the spot on the diagram that says MANIF PRESS, that is the vac tree.
  13. #53 Re: Top swap not making power! Help
    May 2012
    Phoenix, AZ
    The red hose is connected to the BBV. Black hose is connected to the MAP sensor that is in the pic.
  14. #54 Re: Top swap not making power! Help
    GTP Level Member 01gpgt01's Avatar
    Hagerstown,Md
    The BBV should not be seeing boost. The BBV should be hooked up to a vac line between the tb and the rotors(like the top of the blower outlets)
    2001 GT. A few here and there mods http://www.streetfire.net/video/2001...ynp_208097.htm
    2009 Hummer H3 Solar flare premium
  15. #55 Re: Top swap not making power! Help
    May 2012
    Phoenix, AZ
    The dyno shop plugged this part.
    The hose coming off the fuel rail is going to the throttle body.
    THis is the By-pass solenoid right? nothing connected and no wiring for it.
    Nothing is connected to which i believe is the by pass solenoid. and nothing connected to the back of the BBV which is seen in the pic as well.
    This connector is cracked that is going into the throttle body, which one of the hoses coming from it is going to the the fuel rail in the pic above.
  16. #56 Re: Top swap not making power! Help
    thats all pretty much not done right. at all.
    pic of your vac tree, if this is a 97 sc. i dont see it.
  17. #57 Re: Top swap not making power! Help
    Moderator DanPrixGTP's Avatar
    Jun 2011
    Grand Rapids, Michigan
    That vac routing is wrong. Ive already spotted a few mistakes
  18. #58 Re: Top swap not making power! Help
    May 2012
    Phoenix, AZ
    Quote Originally Posted by 01gpgt01 View Post
    I was comparing mine to the diagram and I realize where everything needs to go, but my problem is that I don't have an electrical piece to go into the bypass solenoid. Will that matter?
  19. #59 Re: Top swap not making power! Help
    you need to wire something up i believe, with any luck Bill will stop by and comment on it.
  20. #60 Re: Top swap not making power! Help
    Jun 2011
    Looks like your also missing a vac line that goes onto the BBV if im not mistaking.
  1. not making the power
    By sprattzvx in forum PCM Tuning
    Last Post: 10-18-2011, 03:47 PM
  2. Replaced Power Steering pump, now making noise.
    By fri3dchick3n in forum General Tech Discussion
    Last Post: 05-14-2011, 03:06 PM
  3. Possible to swap mirror from standard to power?
    By cboth686 in forum General Tech Discussion
    Last Post: 08-15-2010, 12:45 AM
  4. More Low/Midrange power... without doing a top swap.
    By BlownBigBlock in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-12-2010, 08:20 AM
  5. Making a L67 RWD...My S10 swap plans
    By Pittman06 in forum Off Topic Discussion
    Last Post: 12-19-2009, 11:38 PM
