hi all.
couple of questions for the gurus if you can be bothered.
i have an l67 that runs a stage 2 intense blower cam and a 25mm composite w2a intercooler setup, along with all the supporting mods like double roller 105 springs etc etc.
firstly, its not really making the power it should be. it drives sweet and idles nice good economy etc, but should be a little quicker. i use tuner pro software and have it dialled in pretty good. running a 79mm pulley im getting 14-15 degrees advance with only occasional knock, which for our aussie blowers with the u bend is pretty good. using 98 octane. a/f at wot is around 11.3.
i have no vac leaks and compression is good. tuning with a wide band.
which brings me to my first question, at wot throttle in first gear its pig rich like 10.3, but when it hits second its nice at 11.3. no amount of fiddling with pe multipliers or injector constants can fix this without upsetting the a/f ratios in the other gears.
im running a surge tank with a bosch 044 stock reg maybe the stock reg is not upto controlling the fuel pressure, but this should happen regardless of gear. is there any where in the tune that might cause this, before i start replacing the fuel system hardware piece by piece?
cheers guys.
