Thread: Will a coolant overflow bottle from a 99 fit onto a 97?
Results 1 to 8 of 8
  1. #1 Will a coolant overflow bottle from a 99 fit onto a 97?
    GTX Level Member Doug 97 gtp's Avatar
    Sep 2011
    palm harbor florida
    i got a 99 coolant bottle from the junkyard and i was wondering if it would fit into a 97 gtp?
    1997 GTP . repainted in jet black with blue pearl. rebuilt motor
    with vs cam ported heads and blower.
  2. #2 Re: Will a coolant overflow bottle from a 99 fit onto a 97?
    Why not? lol...
    Just drill the strut tower and mount it.
  3. #3 Re: Will a coolant overflow bottle from a 99 fit onto a 97?
    Sep 2011
    palm harbor florida
    ok i was just making sure thats all
  4. #4 Re: Will a coolant overflow bottle from a 99 fit onto a 97?
    Texas
    Easiest way is to just to use self tapping screws. How I did mine.
    85 Corvette
    01 TA
    03 Z06
  5. #5 Re: Will a coolant overflow bottle from a 99 fit onto a 97?
    If you don't have traction control, yes it will. If you have traction control...the module is in the way on the firewall. I've seen a few that modded the 99 bottle to make it fit.
  6. #6 Re: Will a coolant overflow bottle from a 99 fit onto a 97?
    Texas
    Except 97's don't come with traction control.
    85 Corvette
    01 TA
    03 Z06
  7. #7 Re: Will a coolant overflow bottle from a 99 fit onto a 97?
    I believe some may have had the option. Regals did, other W bodies did. Pretty sure it was optional.
  8. #8 Re: Will a coolant overflow bottle from a 99 fit onto a 97?
    Texas
    No in 97 it was disabled for GTP's and since he has a GTP its the reason I stated what I did:
    The 97s DO NOT have tire pressure sensors. The 97s have the Delco Delphi ABS system, which could not handle the GTP power for TCS. So TCS was disabled on the 97 GTP, but works on the GT and SE. The “Tire Pressure” light was part of the Delphi ABS system; it did not sense pressure but noticed differences in tire rotation speed. When the Delphi was replace with Bosch, TCS was enabled but the “tire pressure” light was lost.
    97 - 06 GTP Model Differences | ZZP News
    85 Corvette
    01 TA
    03 Z06
  1. Oil in Coolant overflow bottle
    By Oxfire in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-05-2012, 02:35 PM
