This is before taking it to the dyno tune
http://i1322.photobucket.com/albums/...edownload.jpeg
My next question would be, TB spacer?
Why?
[QUOTE=scottydoggs;918811]re looking, the vac line at the left front rail there, it should have a T and then go to another T under the sc snout, in the lim.
Are you talking about the black rectangle plug with the yellow butt near the pulley?
no the vac line that runs from right to left, its looks to be ending on the fuel rail, it should have a T there, and then the vac line continues to the nipple under the sc snout on the lim, where there is another T and the line then wraps around the back of the engine to the map sensor i believe its called.
The line is a hard vacuum line that goes from the bottom of the boost bypass valve over to that T, you can follow it directly, the T is then plugged into the nipple on the lim, and the other side on the T goes around to the back of the motor to the MAP sensor.
As far as I can remember, that's all that's connected to that line.
right above the #1 in that first pic, 1 inch up on the fuel rail is a T, you dont have a T there in your pic. from that T the line runs under the snout to pic #2 to that T. then off to the rear of the engine to the map sensor. little black box over the rear valve cover, the line goes on a nipple under the map sensor.
