Thread: Is it just me? CAI problems
Results 1 to 20 of 20
  1. #1 Is it just me? CAI problems
    Nov 2011
    Bloomington IL
    I had a CAI on my car for about a year then took it off due to some whining at idel and I wanted to make sure it wasnt just coming from my sc because of the intake.
    So I put intake back on the car and after 10 minutes of driving the entire car starts to fall apart. I get numerous warnings on traction control, stability control, reduced power, and my RPMs are all over the place at idle. The whole engine started to shutter and I seriously thought it was about to explode.
    The only thing I did that was different was that I put the intake back on. Am I just a terrible mechanic or did I just have a slight oversight or is my engine seriously about to erupt?
    05 GTP. K&N Intake and magnaflow mufflers, plog-cross-rear exhaust with 3' DP. (Soon to be 3.6 and ported SC)
  2. #2 Re: Is it just me? CAI problems
    GTP Level Member winterstorm's Avatar
    Jun 2012
    Connecticut
    something might have gotten in the intake when you took it off and then got in the engine which can destroy it. thats just a complete guess but its still very possible.
    2005 Grand Prix GT
    Corsa Sport Catback, Thrasher Shift Kit, Custom Open Cone Intake, Spyder Chrome CCFL Halo Projector Headlights, CG LED Tail Lights, Pioneer DEH-33HD stereo unit, Alpine SPR-60C 2 way 6 1/2's, Kicker KS 6x9's
  3. #3 Re: Is it just me? CAI problems
    check your maf out.
  4. #4 Re: Is it just me? CAI problems
    Nov 2011
    Bloomington IL
    Quote Originally Posted by mwinters29 View Post
    I did forget to put the oil cap back on but I didnt drive very far before it happened. Now that the stock intake is back on everything is working perfectly again
  5. #5 Re: Is it just me? CAI problems
    Jun 2012
    Connecticut
    thats odd. it was probably something with the MAF then
    2005 Grand Prix GT
  6. #6 Re: Is it just me? CAI problems
    Nov 2011
    Bloomington IL
    I dont think I put it on backwards, I was too busy with getting it back to normal to notice
    QUOTE=mwinters29;849601]thats odd. it was probably something with the MAF then[/QUOTE]
  7. #7 Re: Is it just me? CAI problems
    open the oil cap, see if it runs bad again like that.. could be a clogged pvc valve or something like that.
    with the cap open, and the car running, you should have no suction, so put the palm of your hand over it to feel for it sucking in. if not your ok. if its sucking you got a problem.
  8. #8 Re: Is it just me? CAI problems
    Nov 2011
    Bloomington IL
    Thanks for the advice Ill keep you guys posted
  9. #9 Re: Is it just me? CAI problems
    Nov 2011
    Bloomington IL
    Good news. No suction on the oil cap hole. Everything seems to be running smoothly
  10. #10 Re: Is it just me? CAI problems
    Pennsylvania
    Probably knocked the wires on the PCM loose.
  11. #11 Re: Is it just me? CAI problems
    Quincy, Mass
    what he said ^^
    i was thinking that if you had to disconnect the pcm to install the CAI then maybe you didnt tighten it all the way when you plugged it back in.
    No more GP 04 Impala SS Indy:
  12. #12 Re: Is it just me? CAI problems
    Nov 2011
    Bloomington IL
    [QUOTE=Swiggles;850717]what he said ^^
    i was thinking that if you had to disconnect the pcm to install the CAI then maybe you didnt tighten it all the way when you plugged it back in.[/QUOTE
    Now that I think about it thats probably what happened. Thanks for the help guys
  13. #13 Re: Is it just me? CAI problems
    GTX Level Member asite57's Avatar
    Oct 2011
    Michigan
    im just wondering whats wrong with have suction when the oil cap is off? my friend just did his LIM job and if the cars running and you pull the oil fill cap off then it stalls the car isnt that normal to have the much vacuum
    SOLD. 99 GTP - Open Cone, ZZP STB ,GMPP Front & Rear Sway Bar, 3" DP & Cat-Back, Built Trans, 12'' Brakes, Tune
    http://www.grandprixforums.net/gtp-t...ack-67489.html
    04 SRT4 - Bone Stock....For Now
  14. #14 Re: Is it just me? CAI problems
    means your PCV is blocked.
    fix it.
  15. #15 Re: Is it just me? CAI problems
    Oct 2011
    Michigan
    so you shouldnt have that much vacuum? ive never seen a "successful" LIM job before
  16. #16 Re: Is it just me? CAI problems
    You measure vacuum in the manifold, not the crank case.
  17. #17 Re: Is it just me? CAI problems
    Oct 2011
    Michigan
    No there's so much vacuum in the engine that if remove the oil fill cap while the engine is running it will stall out the car
  18. #18 Re: Is it just me? CAI problems
    GTX Level Member TEK310's Avatar
    Mar 2012
    Dallas
    i was taught in school that you can put a card over your oil fill hole. if it blows it off, your PCV is clogged, if there is slight suction it is working.
    that also makes sense. if your pcv is clogged, crank case pressure can not vent, and it would blow the card off the oil fill hole.
    of course you can also do the rattle test. take out your pcv, shake it. if it rattles it is good.
    edit> you more than likely left a vac hose undone. when i deleted my evap system, i left the hole on my tb unplugged, car felt like i had plug wires swapped around and i was in a earthquake. plugged the nipple on the tb and back to normal
    2012 Competition Orange Boss 302 #1769 438rwhp 391rwtq
    intake - off road h pipe - e85 - tune
  19. #19 Re: Is it just me? CAI problems
    Apr 2009
    Fort Worth TX
    PCV can fail closed or open.
    Closed - to much pressure in crank case
    Open - to much vacuum in crank case
  20. #20 Re: Is it just me? CAI problems
    Mar 2012
    Dallas
    Quote Originally Posted by Rico View Post
    true
  1. Several Problems
    By kesey in forum 3.1L V6 (LHO/LG8)
    Last Post: 06-14-2012, 05:58 AM
  2. ABS Problems
    By Logan541 in forum Brakes/Suspension/Chassis
    Last Post: 12-12-2011, 05:49 AM
  3. Dic ABS TCS problems
    By Boosted98Gtp in forum General Tech Discussion
    Last Post: 10-06-2010, 11:01 PM
  4. Still having problems
    By fudhimself in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-19-2010, 08:26 PM
  5. 01 GT problems
    By Baumku in forum General Tech Discussion
    Last Post: 04-06-2009, 10:45 PM
