Thread: 1999 Grand Prix GTP DTC P0303
Results 1 to 12 of 12
  1. #1 1999 Grand Prix GTP DTC P0303
    Aug 2012
    Danville
    Hi,
    I'm new to this forum and just purchased a 1999 Grand Prix GTP with 113,000 miles. Driving it home from work today it threw the P0303 code which means cylinder 3 misfire. How can I check to see what the problem is? Thanks.
  2. #2 Re: 1999 Grand Prix GTP DTC P0303
    Houston
    Check your plug, check your plug wire, check the coil labeled 3 for corrosion. And welcome to the forum!
  3. #3 Re: 1999 Grand Prix GTP DTC P0303
    Aug 2012
    Danville
    Thanks KeithGTP03. I checked the coil for #3 cylinder and it was corroded. I also checked the plug and it was at .070" gap instead of .060". I cleaned the coil stud with sandpaper and it still threw the code. I then switched the #3 spark plug wire with the another one and it didn't throw a code after that. It did start missing again at higher speeds but didn't throw any codes. I will change the wires and plugs tomorrow and clean the coil posts and hope that takes care of it.
  4. #4 Re: 1999 Grand Prix GTP DTC P0303
    Houston
    Cool, good luck! If it continues, the next step would be swapping the coils around and see if it follows the coil. If it still misses on #3, time to swap the injector with the one next to it and see if it follows the injector. If it continues after that, you're gonna need to compression test cylinder 3.
  5. #5 Re: 1999 Grand Prix GTP DTC P0303
    Make sure you buy the correct plugs.
  6. #6 Re: 1999 Grand Prix GTP DTC P0303
    GTP Level Member Javi's Avatar
    OKC, Oklahoma
    Make sure you buy the AC Delco plugs.
    fixed
  7. #7 Re: 1999 Grand Prix GTP DTC P0303
    Aug 2012
    Danville
    Just a follow up. I changed the spark plugs, spark plug wires, air filter and changed the oil with Mobil 1 0W-30 synthetic along with the oil filter and it ran great. No missing and it had better power than before. I put in Champion 7940 plugs and gapped them a .058. Thanks for the advice.
  8. #8 Re: 1999 Grand Prix GTP DTC P0303
    Well you didnt buy the correct plugs.
    Platinums and champions dont work well with these car.
    It may be okay for now, but in a while you'll be back to the original problem because the waste spark ignition system will eat away at the plugs.
    Ac Delco Iridiums are the best.
  9. #9 Re: 1999 Grand Prix GTP DTC P0303
    Champions work best in Chryslers, motorcrafts work best in fords and Ac Delco work best in GM cars.
    Iridium plugs are made for the gm cars. Platinums are just cheap plugs that burn out with our ignition system.
  10. #10 Re: 1999 Grand Prix GTP DTC P0303
    I was just hoping he'd research it.
  11. #11 Re: 1999 Grand Prix GTP DTC P0303
    Aug 2012
    Danville
    What is the reason that platinum or Champion plugs won't work well while AC Delco's do?
  12. #12 Re: 1999 Grand Prix GTP DTC P0303
    Aug 2012
    Danville
    Champion also makes plugs for GM original equipment service and SPO. Also some O.E plugs for GM, Ford, Mercedes, Fiat and etc. GM requested the platinum over the iridium because of the cost savings and the waranty rating is about the same. The iridium plugs only advange was the 120,000 mile O.E. waranty and the Platinum plugs were 100,000 mile O.E waranty. I was just curious why AC Delco plugs were favored for the grand prix other than marketing. Thanks.
  1. is the 1999 grand am stereo the same as a 2001 grand prix gt?
    By llinziee in forum Audio, Security & Visual Electronics
    Last Post: 07-06-2011, 03:51 PM
  2. I need some help with my 1999 Grand Prix GTP!
    By Melissa91 in forum General Tech Discussion
    Last Post: 05-24-2011, 08:24 PM
  3. 1999 Grand Prix no go
    By Kreitoc in forum General Tech Discussion
    Last Post: 09-27-2009, 03:37 PM
