Thread: oil light flickering at idle
Page 1 of 3 123 LastLast
Results 1 to 20 of 48
  1. #1 oil light flickering at idle
    GTX Level Member GTPSHAWTY's Avatar
    brunswick
    My oil light flickers ar idle... new pressure switch fresh oil change and its full.... the car has to be ran in about twenty miles before it starts... don't tell me to get a gauge cause that won't fix the problem.... no valve tick no knocking...thank god.... no bad signs.... soooo what to do.... suggestions guys and gals
    CTRACER: YOU SHUT YOUR MOUTH WHEN YOUR TALKING TO ME
  2. #2 Re: oil light flickering at idle
    Mar 2012
    NC
    My guess is weak oil pump.
  3. #3 Re: oil light flickering at idle
    brunswick
    Why would it only do it sometimes
  4. #4 Re: oil light flickering at idle
    Mar 2012
    NC
    As the oil heats up it gets thinner thereby causing lower oil pressure.
  5. #5 Re: oil light flickering at idle
    slap a pressure gauge on it asap before you swap it again.
  6. #6 Re: oil light flickering at idle
    15w40 Rotella??
    But really, it could be the oil pump or something even blocking the oil pick up tube.
  7. #7 Re: oil light flickering at idle
    Apr 2009
    Fort Worth TX
    If it's a used motor then the main bearing clearances are probably greater than 0.003".
    Make sure the pressure bypass port isn't all beat up.
    Check where the gerotor rides against the front cover. If it's all scored and scratched your pump will lose it's efficiency at idle.
    This is exactly why I take a used motor apart before installation.
  8. #8 Re: oil light flickering at idle
    brunswick
    I know the spring and cap thing in the oil neck was stuck before will it locking up again cause that¿
  9. #9 Re: oil light flickering at idle
    Mar 2012
    NC
    YES
  10. #10 Re: oil light flickering at idle
    Apr 2009
    Fort Worth TX
    Quote Originally Posted by GTPSHAWTY View Post
    If it has locked up then it's probably all beat to hell and yes, it could let oil pressure bleed through the bypass circuit. Take the plug/spring out and inspect it. I think it's a good place to start.
    I know you don't want to hear it but - put a gauge on it. See what the idle pressure is. For your sake I hope it's above 10 psi.
    Dude, I really wish I could be there to help you.
  11. #11 Re: oil light flickering at idle
    brunswick
    Ok well I'm going to get on Friday. And I'm taking the neck off Thursday... ill test the pressure tomorrow
  12. #12 Re: oil light flickering at idle
    Apr 2009
    Fort Worth TX
    Good Man!
    I remove the neck by removing the axle first...makes it much easier. I know someone will want to beat me up but I can have an axle off in about 15 minutes with hand tools.
    We'll be looking forward to your next post(s).
  13. #13 Re: oil light flickering at idle
    brunswick
    That's too much lol tire off Max.. .
  14. #14 Re: oil light flickering at idle
    brunswick
    Its gettin worse now it stays on. 2k psi but the engine runnin hotter
  15. #15 Re: oil light flickering at idle
    oh boy, tick, tock, tick, tock, tick, tock, tick, tock.
  16. #16 Re: oil light flickering at idle
    Apr 2009
    Fort Worth TX
    If you aren't going to take the engine apart immediately put some higher viscosity oil in it to prolong it's life for a few days.
    You can save the motor if it's not knocking yet but you have to know what you're doing.
    Excuse me for my ignorance but what does 2k psi mean?
  17. #17 Re: oil light flickering at idle
    Must mean 2k rpm. Which means whatever is causing the low oil pressure...it's getting worse. I'd suspect a bearing wearing out with the lack of oil, but tearing it down would tell you for sure.
    PS. Chuck..it's pull the axle and make the job easy or fight for three times as long and not use the correct torque on the bolts. Although I prefer to pull it when the engine is out of the car.
  18. #18 Re: oil light flickering at idle
    brunswick
    Ii did mean rpm.... And i just pit this **** back together.... Any other things to try before taaking the engine out
  19. #19 Re: oil light flickering at idle
    Realizing you are against gauges, it would tell you if the issue was truly oil pressure as we are guessing that it is.... can't be sure w/o testing though.
  20. #20 Re: oil light flickering at idle
    brunswick
    K I'm getting the tester today and checking it.... do I take the sending unit out or what
  1. Engine Light on code P0171, IDLE SURGING!
    By balzi in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-07-2013, 01:51 PM
  2. temp light flickering
    By natejames99gtp in forum General Grand Prix Discussion
    Last Post: 03-09-2012, 06:34 PM
  3. Flickering DIC
    By jeepers in forum Audio, Security & Visual Electronics
    Last Post: 04-02-2011, 09:24 AM
  4. Coolant light flickering
    By Agentlongwood in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-27-2011, 12:51 PM
  5. Pours blue smoke, wont idle, check engine light flashes!?
    By 1fastz71 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-25-2010, 09:13 PM
