Thread: oil light flickering at idle
Results 1 to 20 of 48
  1. #1 Re: oil light flickering at idle
    GTX Level Member GTPSHAWTY's Avatar
    brunswick
    I know the spring and cap thing in the oil neck was stuck before will it locking up again cause that¿
    CTRACER: YOU SHUT YOUR MOUTH WHEN YOUR TALKING TO ME
  2. #2 Re: oil light flickering at idle
    Apr 2009
    Fort Worth TX
    Quote Originally Posted by GTPSHAWTY View Post
    If it has locked up then it's probably all beat to hell and yes, it could let oil pressure bleed through the bypass circuit. Take the plug/spring out and inspect it. I think it's a good place to start.
    I know you don't want to hear it but - put a gauge on it. See what the idle pressure is. For your sake I hope it's above 10 psi.
    Dude, I really wish I could be there to help you.
  1. Engine Light on code P0171, IDLE SURGING!
    By balzi in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-07-2013, 01:51 PM
  2. temp light flickering
    By natejames99gtp in forum General Grand Prix Discussion
    Last Post: 03-09-2012, 06:34 PM
  3. Flickering DIC
    By jeepers in forum Audio, Security & Visual Electronics
    Last Post: 04-02-2011, 09:24 AM
  4. Coolant light flickering
    By Agentlongwood in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-27-2011, 12:51 PM
  5. Pours blue smoke, wont idle, check engine light flashes!?
    By 1fastz71 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-25-2010, 09:13 PM
