Must mean 2k rpm. Which means whatever is causing the low oil pressure...it's getting worse. I'd suspect a bearing wearing out with the lack of oil, but tearing it down would tell you for sure.
PS. Chuck..it's pull the axle and make the job easy or fight for three times as long and not use the correct torque on the bolts. Although I prefer to pull it when the engine is out of the car.
