Quote Originally Posted by GTPSHAWTY View Post
I know the spring and cap thing in the oil neck was stuck before will it locking up again cause that¿
If it has locked up then it's probably all beat to hell and yes, it could let oil pressure bleed through the bypass circuit. Take the plug/spring out and inspect it. I think it's a good place to start.
I know you don't want to hear it but - put a gauge on it. See what the idle pressure is. For your sake I hope it's above 10 psi.
Dude, I really wish I could be there to help you.
