So here is the dilemma ..
I spun a rod bearing in the 04 so I'm gonna build the lower end of the engine while I'm here.. I'm wondering what you guys think on pistons. Should i put je or diamond pistons.. also should I go with stock comp ratio or the na ratio. This will mostly be run on e85 and will be a daily driver. I guess i should clarify the car is a gtp and i have a dhp...
Sent from my DROID RAZR using Tapatalk 2
