Thread: Coolant Question
Results 1 to 5 of 5
  1. #1 Coolant Question
    SE Level Member mlasnoski's Avatar
    Jun 2010
    Marquette, Michigan 49855
    What is the little sensor to the right of the thermostat on a 2004 Grand Prix GTP CompG. It has a little bit of coolant on it. The coolant is orange-ish right? Everything is running fine I just noticed a little bit. Maybe I should just try and tighten the sensor. I just wanted to know what sensor it is.
    Thanks
    Mike
  2. #2 Re: Coolant Question
    most likely the coolant temp sensor.
  3. #3 Re: Coolant Question
    Banned
    Sioux Falls, SD
    That is you coolant temp sensor, if it has coolant coming from it u might want to pull it out and clean the thread and put Nylon tape back on it. This would be a great time to change coolant since u will be loosing some. You could change to green coolant.
  4. #4 Re: Coolant Question
    Jun 2010
    Thanks! How much will I loose if I take it off and clean it up?
    I'm sort of engine savvy, but I don't have the ability to change my coolant right now, I live in the city and don't have a place to change it.
  5. #5 Re: Coolant Question
    Banned
    Sioux Falls, SD
    you'll lose whatever is in you Lower intake manifold, im not sure how much.
  1. Coolant temp sensor question
    By TEK310 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-07-2012, 08:52 AM
  2. coolant question
    By louisgtp in forum General Tech Discussion
    Last Post: 03-08-2012, 08:05 PM
  3. 2004 GP Coolant Temperature Question
    By Chad Gervais in forum General Grand Prix Discussion
    Last Post: 03-04-2012, 08:25 PM
  4. dumb coolant level question
    By MrTube in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-12-2010, 02:32 PM
  5. Engine Coolant Question
    By dowtrader in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-11-2008, 03:03 PM
