Thread: noise from supercharger
Results 1 to 6 of 6
  1. #1 noise from supercharger
    ontario
    hey everyone,
    i noticed the other day a noise coming from under the hood and upon further inspection i found it to be at the supercharger. right around where the snout bolts to the rotor housing.
    the noise sounds kind of like a loose heat shield rattle or grinding noise, or a bearing scratching noise.
    any help or suggestions would be good
    its an m90 ported and modified for the ssm90 kit by zzp
    thanks
    Mike
  2. #2 Re: noise from supercharger
    Charles City, IA
    If its a rattle sounds like a bad coupler. Grinding sounds more like bad bearings.
    SMGPFC Two Nipple General
  3. #3 Re: noise from supercharger
    Your ClubGP Liason copgtp's Avatar
    Orange County, NY
    It's more than likely your coupler.
    For all your 3800 needs:
  4. #4 Re: noise from supercharger
    ontario
    you guys think this would be warrantied by zzp?
    also what are some ways that i can verify bearings or coupler ??
    thanks
    Mike
  5. #5 Re: noise from supercharger
    Charles City, IA
    Take the belt off and see if you can feel any play while rotation the pulley, if so its probably the coupler. I am not sure what zzp has for a warranty on their blowers.
  6. #6 Re: noise from supercharger
    SE Level Member RICE KILLER's Avatar
    st. paul mn
    I have that same problem only my coupler is brand new and still good. so I took the blower apart and found that the rotors had alot of play (i could jiggle them in their rotor pack) meaning that the rotor pack bearings were bad. Also found that I had a bad snout bearing.
    2000 Daytona Pace car, SD Hood, Xp cam, Ported Heads, Gen V, North Star, Headers, ZZP stage 2 Intercooler, 3in Exhaust, and custom tune
  1. SuperCharger Noise
    By Bubweiser21 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-22-2012, 11:47 PM
  2. noise from supercharger
    By johndoe35652 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-01-2011, 02:22 AM
  3. supercharger noise
    By sdenton8 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-25-2010, 06:04 PM
  4. Supercharger Noise
    By Clar2478 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-19-2009, 03:45 PM
  5. Noise in the supercharger
    By xawahl in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-14-2009, 06:58 PM
