Thread: HELP ASAP!! Port and Polishing supercharger
Results 1 to 9 of 9
  1. #1 HELP ASAP!! Port and Polishing supercharger
    SE Level Member GP_Kid18's Avatar
    May 2008
    Palatine,Illinois
    So I am P&P my supercharger before I give it back to my tuner, as I was taking some metal off the two humps (on the left and right if you were to take off the TB an look into the inlet) I took a little too much off the right hump and I made a very small hole, Im not sure as to where I tapped into, I believe it maybe a coolant passage. I have patched the hole with JB weld and tomorrow I am planning on smoothing it out. I am just seeing if there is anything else that I need to do? Will the fix work or do I need a new housing?
    From what I have read this should fix the problem, I just would like some input from people that may have anymore knowledge.
    Any help is very appreicated!!
    Thanks
  2. #2 Re: HELP ASAP!! Port and Polishing supercharger
    Flip the charger over and fill the two coolant ports full. Then fill them from the TB side. Smooth things out and don't worry at all.
  3. #3 Re: HELP ASAP!! Port and Polishing supercharger
    Kansas
    Why are you porting a Gen V?
  4. #4 Re: HELP ASAP!! Port and Polishing supercharger
    Quote Originally Posted by NegativeOne13 View Post
    Where's he say V?
  5. #5 Re: HELP ASAP!! Port and Polishing supercharger
    Where's he say V?
    He has an '04.
  6. #6 Re: HELP ASAP!! Port and Polishing supercharger
    Cheaters!
  7. #7 Re: HELP ASAP!! Port and Polishing supercharger
    sooo....muchhhh...redddddddd
  8. #8 Re: HELP ASAP!! Port and Polishing supercharger
    Charles City, IA
    I was going to smooth the inlet on my v but then got lazy and bolted it on.
    SMGPFC Two Nipple General
  9. #9 Re: HELP ASAP!! Port and Polishing supercharger
    I did smooth it. The curves in there, aren't really cooperative though.
  1. Supercharger Port & Polish
    By gtp02 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-31-2011, 11:24 AM
  2. polishing supercharger
    By fremmy182 in forum General Tech Discussion
    Last Post: 12-17-2010, 09:45 PM
  3. supercharger i/o port
    By PhunnyJesta in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-08-2010, 02:00 PM
  4. Please Read ASAP, Need all ur input asap
    By SteelCityTA in forum Off Topic Discussion
    Last Post: 03-29-2009, 02:41 AM
  5. DIY Polishing??
    By Iron Indian in forum Visual/Body Modifications
    Last Post: 02-06-2008, 07:20 PM
