Thread: noise from supercharger
Results 1 to 5 of 5
  1. #1 noise from supercharger
    Nov 2010
    Rogersville
    when at idle sounds like rattle in the charger. with a little gas it goes away. What is causing this?
  2. #2 Re: noise from supercharger
    SE Level Member fst4dr's Avatar
    Calgary
    The coupler in the sc you need to replace I think all the 3800 vendors sell them.
    1998 4dr GTP Bright Red
    180* Stat/FWI/ZZP PCM/SD Headers/MPS 3.4/104's/6000k H.I.D/Tinted tails/Eibach's/GMPP STB/12'' Brake upgrade/18'' Ruff Black/Machined
  3. #3 Re: noise from supercharger
    Jul 2008
    sumter,south carolina
    if it sounds like rocks tumbling around in the supercharger u will need a coupler. needle bearings have their own lil sound too if they go bad. here is the coupler link... its the most common thing to go wrong and its cheap and easy to fix.
    ZZ Performance
    02 GTP with mods 05 GP for DD
  4. #4 Re: noise from supercharger
    heres a vid on how easy it is to change, you can get the coupler off ebay for 20 bucks if you want, but use the gm sc oil, its strongly recommended.
    YouTube - Replacing a worn out supercharger coupler on 3.8 GM engines
  5. #5 Re: noise from supercharger
    Nov 2010
    Rogersville
    Thanks for all the help now I can make it quiet.
  1. SuperCharger Noise
    By Bubweiser21 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-22-2012, 11:47 PM
  2. supercharger noise
    By sdenton8 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-25-2010, 06:04 PM
  3. Engine noise Supercharger??
    By drewz313 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-16-2009, 04:45 PM
  4. Supercharger Noise
    By Clar2478 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-19-2009, 03:45 PM
  5. Noise in the supercharger
    By xawahl in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-14-2009, 06:58 PM
