Yep, left had drill bits work great. Snap on has them also. You can also use a centerdrill to get started. If your drill is leading off, a centerdrill is your best bet, or as stated above use a die grinder with a small bit to grind a center starting point in the end of the broken bolt. A mapgas hand held torch can help as well.
