Thread: HELP! Power Steering Bolt Broke Off in Block
Results 1 to 19 of 19
  1. #1 Re: HELP! Power Steering Bolt Broke Off in Block
    GT Level Member RegalGS98s's Avatar
    NJ
    Quote Originally Posted by jpearsall187 View Post
    I am having great difficulty drilling a hole. The bits keep breaking. Are there any special type of super hard, super sharp drill bits i can use? Also, if I have to end up tapping this hole for a new bolt, what is the next size up that will do the job but the bolt will still fit through the power steering pump? Thanks
    Don't remember the bolt size, but for drill bits, titanium coated and cobalt drill bits are the better bits. The cobalt one's are considered better, but can cost you $50 easily. If you do get the cobalts, don't let the small bits get wobbly and break off. You'll have even more fun trying to drill out cobalt with another cobalt drill bit. I usually use some cutting oil with the bits to keep them cool and drill easier.
    SMGPFC #0330 - 3.25, Intercooled, Custom Tune, 1.84rr, LS6 Springs, roller timing chain, SLP Headers, Borla Exhaust, built Trans, B&M Trans Cooler, home cut poly uppers, gapless rings, N* TB, Ported heads.
    Soontocome: CAM?, Custom modified M112, home poured Poly Engine and Trans mounts
  2. #2 Re: HELP! Power Steering Bolt Broke Off in Block
    NJ
    Another idea of getting this out is if you know someone who welds, they could try welding a nut onto the end of the broke off bolt. Once it cools, back it out going in both directions to free it. This works sometimes, and others it just keeps breaking off and then u have to drill or grind through a weld and then the original broke off bolt. I think grinding the stud flat with the die grinder and drilling it out is still your best bet, but throwing out other ideas. If you do drill it out, I use left hand drill bits once I get most of it drilled out, usually I don't have to do any retapping after that cause it catches the stud and backs it out. I use these: 13 Piece Left-Hand Drill Bit Set When drilling, just have to be patient, don't try forcing it to drill the hole faster, once you break the surface, usually it gets easier to drill. As others said, don't drill too deep. Take measurement from another bolt and tape off on your drill bit for measurement.
  1. idler pulley bolt broke
    By ramp in forum General Tech Discussion
    Last Post: 02-04-2011, 06:37 PM
  2. bolt broke off mount brackets to block,where can i find new bolt
    By crystalterry89 in forum General Tech Discussion
    Last Post: 10-21-2010, 06:28 PM
  3. Inline fuse / fused power distribution block
    By Slueth66 in forum Audio, Security & Visual Electronics
    Last Post: 03-20-2010, 12:12 AM
  4. Exhaust Manifold Bolt broke
    By Deathwish99 in forum Off Topic Discussion
    Last Post: 02-27-2010, 08:24 PM
  5. Booger I broke Power Steering line
    By SDGTP99 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-15-2009, 10:08 AM
