Thread: HELP! Power Steering Bolt Broke Off in Block
Results 1 to 19 of 19
  1. #1 Re: HELP! Power Steering Bolt Broke Off in Block
    Apr 2011
    Gainesville, FL
    So the bolt is broken off jagged inside the hole. It is not a flat surface, so drilling it in the center is probably not possible as the bit always travels toward the edge. Does anyone have any suggestions on how to center it? Also, anyone have a quick run down on how to drop the passenger side of the engine cradle. I think I may have done it once before when I did the rack and pinion, but I forget what's involved. Just trying to plan. Thanks
  2. #2 Re: HELP! Power Steering Bolt Broke Off in Block
    man that sucks, the only ting i can think of is if you make some kind of jig to hold the bit centered.
    maybe trace the back of the pumps bolt holes and drill the holes out of a thick piece of flat stock, bolt the good bolt through the jig and line the other hole up with the broken bolt and try to drill it out.
    come to think of it, if you pull the pumps pulley off you could maybe use the pump its self to line up the drill bit.
  1. idler pulley bolt broke
    By ramp in forum General Tech Discussion
    Last Post: 02-04-2011, 06:37 PM
  2. bolt broke off mount brackets to block,where can i find new bolt
    By crystalterry89 in forum General Tech Discussion
    Last Post: 10-21-2010, 06:28 PM
  3. Inline fuse / fused power distribution block
    By Slueth66 in forum Audio, Security & Visual Electronics
    Last Post: 03-20-2010, 12:12 AM
  4. Exhaust Manifold Bolt broke
    By Deathwish99 in forum Off Topic Discussion
    Last Post: 02-27-2010, 08:24 PM
  5. Booger I broke Power Steering line
    By SDGTP99 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-15-2009, 10:08 AM
