Thread: bolt broke off mount brackets to block,where can i find new bolt
Results 1 to 14 of 14
crystalterry89 bolt broke off mount brackets... 10-20-2010, 05:41 PM
Bio248 Re: bolt broke off mount... 10-20-2010, 06:46 PM
crystalterry89 Re: bolt broke off mount... 10-20-2010, 06:48 PM
Bio248 Re: bolt broke off mount... 10-20-2010, 06:54 PM
crystalterry89 Re: bolt broke off mount... 10-20-2010, 06:58 PM
matt5112 Re: bolt broke off mount... 10-20-2010, 07:07 PM
crystalterry89 Re: bolt broke off mount... 10-20-2010, 08:22 PM
Lawngoose Re: bolt broke off mount... 10-20-2010, 09:58 PM
DanGTP Re: bolt broke off mount... 10-20-2010, 11:34 PM
BillBoost37 Re: bolt broke off mount... 10-21-2010, 07:09 AM
crystalterry89 Re: bolt broke off mount... 10-21-2010, 08:57 AM
BillBoost37 Re: bolt broke off mount... 10-21-2010, 09:36 AM
Deviq Re: bolt broke off mount... 10-21-2010, 12:47 PM
DanGTP Re: bolt broke off mount... 10-21-2010, 06:28 PM
  1. #1 bolt broke off mount brackets to block,where can i find new bolt
    valparaiso,in
    my bolt to my mount bracket that bolts to the block is missing, how do i find out what size bolt to buy, even if someone has a general idea on where to start with sizing, I have no clue and do not want to buy the whole mount for just one bolt. thanks so much!
  2. #2 Re: bolt broke off mount brackets to block,where can i find new bolt
  3. #3 Re: bolt broke off mount brackets to block,where can i find new bolt
    valparaiso,in
    thanks, could you help direct me to a new section, please i joined today to ask this. thanks so much!
  4. #4 Re: bolt broke off mount brackets to block,where can i find new bolt
  5. #5 Re: bolt broke off mount brackets to block,where can i find new bolt
    valparaiso,in
    well thanks sooo much.
  6. #6 Re: bolt broke off mount brackets to block,where can i find new bolt
    There are many "mount brackets"
    which one are you referring to?
  7. #7 Re: bolt broke off mount brackets to block,where can i find new bolt
    valparaiso,in
    all i know is they are underneath not on top.as far as my research goes im pretty sure there is the two on bottom(transmission and other one) and then the one on top.????
  8. #8 Re: bolt broke off mount brackets to block,where can i find new bolt
    Outer Space
    Take a picture
    02 GTP 13.6 @ 100mph - SOLD
  9. #9 Re: bolt broke off mount brackets to block,where can i find new bolt
    Feb 2008
    I'm assuming you're referring to the cradle that bolts to the block and goes under the passenger side of the engine?
  10. #10 Re: bolt broke off mount brackets to block,where can i find new bolt
    I'm usually good with newbs and odd descriptions for the parts we all know and love..... you got me stumped as to what you are talking about.
  11. #11 Re: bolt broke off mount brackets to block,where can i find new bolt
    valparaiso,in
    first off, im a women and we make everything more confusing lol and second i took my car to car x to have them tell me what was wrong with it cus i had a real bad wheel hop or front end shake, and this is exactly what he wrote on my service invoice:engine mount brackets that bolt to block are missing bolts. engine is shifted to the right causing l/f axle to bind. lift engine-align bracket holes-install bolts-replace mounts if needed.
    So I know when he had the car up in the air and showed me, one was on the driver side, and one was on the passenger side,both underneath the car.
    If i am still confusing you then dont worry about it haha, i just dont want to cave and pay their outrageous prices.
  12. #12 Re: bolt broke off mount brackets to block,where can i find new bolt
    Oh..Car X.. yikes. I've heard stories and am thankful we don't have them around here.
    Sounds like your motor and transmission mounts are bad. The missing bolt part, well there are some bolts that shouldn't be able to loosen themselves or come free...shouldn't. The motor shifting like the description says, sounds like a bad motor mount more than anything else.
  13. #13 Re: bolt broke off mount brackets to block,where can i find new bolt
    GT Level Member Deviq's Avatar
    SE WI
    Quote Originally Posted by zildjian102
    .. friggin trashy people. I did stuff with their daughter
  14. #14 Re: bolt broke off mount brackets to block,where can i find new bolt
    Feb 2008
    Based on the description alone, I'd say take the car to someone else!
    But, it does sound like something to do with motor mounts and/or their brackets.
  1. i need engine mount brackets
    By merciero in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-15-2010, 05:53 PM
  2. need trans mount brackets
    By merciero in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 10-14-2010, 07:56 PM
  3. Exhaust Manifold Bolt broke
    By Deathwish99 in forum Off Topic Discussion
    Last Post: 02-27-2010, 08:24 PM
  4. Trailing arm mount bolt
    By Fourstringsquire in forum Brakes/Suspension/Chassis
    Last Post: 08-12-2009, 04:49 PM
