Thread: HELP! Power Steering Bolt Broke Off in Block
Results 1 to 19 of 19
  1. #1 Re: HELP! Power Steering Bolt Broke Off in Block
    GT Level Member RegalGS98s's Avatar
    NJ
    If the bolt is broke off inside the hole, I say air grinder with a die grinder bit. Use the end of the die grinder bit. For example: 1/4" Air Die Grinder Kit Just try to watch the sides to keep from making a pain to tap, but at least it shouldn't walk and then try drilling it when you get it flat. Done it a couple times, steady hands needed.
    SMGPFC #0330 - 3.25, Intercooled, Custom Tune, 1.84rr, LS6 Springs, roller timing chain, SLP Headers, Borla Exhaust, built Trans, B&M Trans Cooler, home cut poly uppers, gapless rings, N* TB, Ported heads.
    Soontocome: CAM?, Custom modified M112, home poured Poly Engine and Trans mounts
  2. #2 Re: HELP! Power Steering Bolt Broke Off in Block
    St. Louis
    Well, depending on how soft that bolt is you can use a really fine pointed center punch and smack it a few times to give yourself a divot in the center of the bolt. Then just stick the small drill bit in there as a guide and go to town. Just try and get the punch mark as close to center as possible or you may be retapping that hole for a larger bolt in the end.
    I have actually used a Dremel tool with a grinder bit in it to smooth off recessed broken bolts as you have here, then used the center punch to give me a divot and out it came. Worked on a 93 Villager rear exhaust manifold bolt. Even did it in the van.
  1. idler pulley bolt broke
    By ramp in forum General Tech Discussion
    Last Post: 02-04-2011, 06:37 PM
  2. bolt broke off mount brackets to block,where can i find new bolt
    By crystalterry89 in forum General Tech Discussion
    Last Post: 10-21-2010, 06:28 PM
  3. Inline fuse / fused power distribution block
    By Slueth66 in forum Audio, Security & Visual Electronics
    Last Post: 03-20-2010, 12:12 AM
  4. Exhaust Manifold Bolt broke
    By Deathwish99 in forum Off Topic Discussion
    Last Post: 02-27-2010, 08:24 PM
  5. Booger I broke Power Steering line
    By SDGTP99 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-15-2009, 10:08 AM
