He's taking out his N/A and going to swap in his S/C engine. The point of this thread is what he should do to the engine before it goes in.
I say that since your putting it in before the built transmission, then I would hold off on rockers or cam until you put in the trans. The IC will put plenty of power for a stock trans on a DD. When You put in the trans, it will be easy to install the cam. Rockers can be installed whether the motor is in or out. So you could see what power the your getting with the IC and see if you want to put rockers on. In the end though, a cam will be better for power.
